Oil & Fuel Yearly Maintenance on 1530/ TC30
   / Yearly Maintenance on 1530/ TC30 #1
SpecialED
I recently purchased a New Holland 1530 which seems to be the and older version of the TC30. This is my first "bigger" tractor, I love this thing!!
Can someone give me a little advice on what
I should do for the yearly maintenance? I keep her greased up but
would like to know what else I need t do. I purchased a Service
manual but recently realized I probably need to invest in a Maintenance
manual.
Any help/ suggestions will greatly appreciated!
Thanks,
Ed
   / Yearly Maintenance on 1530/ TC30 #2
Operators manual is what you want. It will have the service interval infromation you need. Generally tractors and the like are maintaned at hours of use. Fifty hours is normally an interval where some of the oils and filters are changed. Some items need closer attention (air filters in dusty conditions come to mind). You should be able to get an operators manual from your local dealer, if not try Ebay. Greg
   / Yearly Maintenance on 1530/ TC30 #3
Not sure on your tractor, but my TC40D has most of the maintenance list on the inside of the hood. Of course, the owners manual has more thorough info.
   / Yearly Maintenance on 1530/ TC30 #4
This was posted on TBN a while back. I think it was something Messicks provided.
  • TC-Service.pdf
Thanks Robert and Larry!
Larry, I found that PDF very informative.
Take Care guys,
Ed
   / Yearly Maintenance on 1530/ TC30 #6
One thing I found interesting, is my previous tract had a dozen or so zerk fittings to grease. My TC40D has more zerk fittings than you can shake a stick at! Which reminds me, today would be a good day to do that :D
   / Yearly Maintenance on 1530/ TC30 #7
Can anyone elaborate on the part about changing the clutch housing oil? A picture or two would be great if possible.
   / Yearly Maintenance on 1530/ TC30 #8
If you have the hydo model I don't think it's relevent. My factory O&M has a page for it but it covers hydro and gear models.
One thing missing from the pdf is changing the front axle and final drive fluid. Same hydraulic fluid used for everything else.
   / Yearly Maintenance on 1530/ TC30 #9
This crappy PDF shows the front drive and final reduction gear items missing in the above PDF but I added the maintenance charts for the 2 and 4 wheel drive. Hope it helps.
By the way, this was from the OM for a 05 TC30
DEUTZ MARATHON...
2015 Komatsu PC490LC-11 Hydraulic Excavator, S/N A42603, PIN# KMTPC251HFWA42603, Turbo Diesel (A59076)
2015 Komatsu...
2009 CAROLINA  16FT EQUIPMENT TRAILER (A58018)
2009 CAROLINA...
LOT: (7) Wheel Loader Shanks (A59076)
LOT: (7) Wheel...
2016 DRAGON SAND CONVEYOR (A58214)
2016 DRAGON SAND...
2019 PJ  40FT GOOSENECK TRAILER (A58214)
2019 PJ 40FT...
