How big of plow 4720
   / How big of plow 4720 #1
Tritonman
Gold Member
Just curious of how big of plow you are pulling with a 4720. I would also be interested in how big of a disc you are pulling. Thanks
   / How big of plow 4720 #2
The 4720 has the HP to pull a large set of plows. However, tire tread type, wheel weight, and soil conditions will dictate how big of a plow and/or disc you can attach.
It will have four wheel weights and solution in the tires and loader on it. So it will be weighted down pretty good. I may just pick up a 8 and a half foot three point disc which I know it will toss around easily but was kicking around a 12 foot used pull type. I also have an eye on a nice four bottom and a three bottom plow, so was curious if anyone tried a four bottom with there 4720
   / How big of plow 4720 #4
Bingo...
I've got a 2 bottom behind my 3520 and seriously, I dont even feel it back there. If it were not for my relatively small garden, I'd be looking for a 3 bottom. But a 3 bottom would be much larger and more cumbersome to manuver around the garden & yard..
I'd say a 4720 would have ZERO problems with a 3 bottom in any soil type and your soil type would dictate if you could pull a 4 bottom.
   / How big of plow 4720 #5
I pull a 6' disc and my 4520 with R1s handles it easily. I would think you should not have any significant issues with a 14", 3 bottom plow. I don't think you would have a chance with a large, 4 bottom plow.
   / How big of plow 4720 #6
I think it is more optimal to pull a slightly smaller disk faster rather than try to pull a wide one. You can get the same amount of work done just have to approach the problem differently with the compact tractors.
   / How big of plow 4720 #7
I would go with A 3 bottom because pulling a low a little faster does a better job of flipping the soil/sod over completely. 6 Ft disc should be fine. Here are a couple we have on Ebay today. You can't find these type rebuilt plows on Craigslist. Ken Sweet
Used 3-14 Inch Oliver Turning Plow with Cat 2 Pins | eBay
Used 3-12 Inch Massey Ferguson Turning Plow # 43--Cat 1 | eBay
2013 Case IH Magnum 315 MFWD Tractor (A50657)
2013 Case IH...
2015 Chrysler 200 Limited Sedan (A48082)
2015 Chrysler 200...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
JCB 5 10 56 (A50490)
UNUSED 20PCS 2in. Polyester Lifting Strap (A50860)
UNUSED 20PCS 2in...
2019 Ford F550 4x4 Bucket Truck with Altec AT41 Boom - 46FT Working Height and Jib Winch (A51039)
2019 Ford F550 4x4...
