Utility grader / scraper: Revision to make it also a box blade
   / Utility grader / scraper: Revision to make it also a box blade #1
beppington
Elite Member
of my
Here
Just an idea:
How about a revision to the utility grader (land plane; road grader; road scraper; whatever they're called) to convert it to a combination utility grader & box blade. Add a flap / blade on the rear that can either be put up where it would lay on top of the grader's frame & the implement works as a grader, or down when you want to use it as a box blade. The flap / blade would be hinged, & you'd pin in it place in its down position for use as a box blade.
attachment.php
attachment.php
   / Utility grader / scraper: Revision to make it also a box blade #2
Thats what I did on mine. Not totally my idea though - I stole some of it from someone else along the way here on TBN. I have a pin one each side for tail gate stops. They are hard to see. If I put the tail gate inside it works like a box blade going forward and holds material in the box. If I swing the tail gate over the top and let it hang on the outside ( like in the picture ) it acts as a drag going forward or like a blade going in reverse so I can push stuff by backing up. If I get a pile of sod I just back into it to get it off the road.
Yeah, there we go!
   / Utility grader / scraper: Revision to make it also a box blade #4
I think that the rear flap like Gordon's is a great idea. I believe that there is at least one manufacturer that does have this as an option. One of the TBN members has one on order as we type. I am curious if it is going to be a gate as Gordon's is or if it might have a cutting edge on it. :cool: Hopefully we will find out in a week or two.
   / Utility grader / scraper: Revision to make it also a box blade #5
I thought about adding a back to my grader, but decided that my poor 70hp JD didn't need any more weight to tote around. Durn thing is heavy!! Besides, it really does carry a lot of dirt as it is, as long as your not trying to transport it, just move it a little way.
David from jax
   / Utility grader / scraper: Revision to make it also a box blade #6
I have been sitting on a piece of 5/8" flatbar to use for this purpose but haven't really decided whether it will work for my uses yet.
A consideration is that when using my plane I prefer to have a good view of the ends of the skids to adjust them up and down. Having a load of dirt back there might be detrimental for this.
If I do add it to mine it will be a flip over type similar to Gordons and should have pins to keep it in the up position too.
   / Utility grader / scraper: Revision to make it also a box blade #7
When I first did mine I was considering putting pins on top to hold it open and also a method of locking it in the down position. I decided to try it first then decide what I needed for improvements. So far ( one season ) for my use I like it as is. Althought neither of those things would be a detriment.
I use the box blade mode ( gate in front of the pins ) for initial spreading of new surface material or if I am working a place with rocks that are being turned up that I want to collect and get rid of. Need to set the top link just right to do this w/o getting to much dirt. Really need a hydraulic TL.
The addition of a blade or blades on the gate, as Brian suggested, would add versatility for sure.
Be careful, Gordon ... I broke my 3PH. Read about it here: http://www.tractorbynet.com/forums/owning-operating/204404-ok-push-trees-over-box.html
When I started this modified grading scraper thread, I fully had in mind using it to push stuff backwards (as well as forward). You can bet I don't anymore.
   / Utility grader / scraper: Revision to make it also a box blade #9
I saw your thread when you posted it - ouch :mad: Thanks for the warning.
You were pushing over trees. I don't think pushing small piles of loose stones and sod are a problem. The stop pin on my tailgate would give first but I am careful and keep the idea of bending things pushing backwards in my mind.
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
1273 (A50490)
1273 (A50490)
2012 KENWORTH T800 (A50854)
2012 KENWORTH T800...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A51039)
2007 Freightliner...
2013 Ford E-350 Enclosed Service Van (A50323)
2013 Ford E-350...
