Ventrac Assembly Videos
/ Ventrac Assembly Videos #41
I figured I would add another point to this thread. I got my VT out for the first time today, to do a little cutting, and make sure that all is in order. While driving along I was thinking about this thread.
One thing I noticed is that the price on my VT 4231, 31 HP, dual wheels, was around 19K. The PT425 does not have a dual wheel option. Also, the motors are in a completely different league. The BS Vanguard 31HP motor on the VT is very expensive. The motor is the #1 difference in the price of the two machines. I think it is overkill, but it is the only gas high HP option for that machine.
Here is what a discount replacement would cost:
Brand New Engines | Briggs & Stratton 3/LC 23.5 HP Vanguard Gasoline Power Unit #825366
Here is a listing for a 25HP Robin: (No muffler but otherwise similarly equipped)
Robin Subaru EH722-DS 25 HP
The difference is roughly $3000. If VT would use less expensive motors, their prices would be more competitive.
The 4231 is somewhere between a PT425 and a PT1845, and it is kind of priced that way.
/ Ventrac Assembly Videos #42
It is a 72" Lastec articulated mower and I have it.
Ha! Thanks for the reminder. How's it working out? My 60" flat deck is O.K. for most humps and dips as long as you attack them up or down. If I go across a hump, I scalp it and if I go across a dip, the grass stays long in the low spots.
In particular, our yard is pretty flat up to the street. Then there is a slight slope down about a foot, followed by a rise of a few inches back to the shoulder of the road. If I hit it perpendicular, it is fine. If I hit it parallel, I leave it long in the dip and scalp the entire width of the yard along the street.
I don't think my PT425 would have enough power to turn a 72" deck. the 60" is pushing the limits with the 25HP Kohler.
/ Ventrac Assembly Videos #43
Maybe we should stop beating this dead horse. Even though they kind of look the same and cover some overlapping tasks, Ventracs and PTs are designed for different basic purposes and aimed at different markets. They both fulfill their design objectives pretty well and satisfy their niche market. This is getting to be like comparing electric guitars with pianos.
/ Ventrac Assembly Videos #44
Amen brother, but what else should we beat?
/ Ventrac Assembly Videos #47
As originally modified by the PT folks it had some problems. Also, when I got it the blades were set up incorrectly. After two significant mods and installing the blades correctly I have been quite satisfied. The articulated 72" Lastec deck handles rough ground much better than the PT 72" deck without scalping. It is also a much better built unit--higher quality fittings, bearings and floatation as well as a sturdier deck with better baffling.
/ Ventrac Assembly Videos #48
We could always beat on the wimpy little PT-180. The good folks at PT once told me a backhoe could never be adapted to... or work on a 180. I love it when someone tells me it won't work or can't be done !!! :licking:
/ Ventrac Assembly Videos #49
Beechwood,
Thanks for reminding me about that. I kinda remember it. Could you post a link?
/ Ventrac Assembly Videos #50
How about the lowly three point hitch? It needs another beating!!! :cool2:
:laughing: :)
Speaking of 3pt Hitch I was talking to my uncle the other day and he said something about putting a 3pt Hitch and and 540rpm PTO on the back of a Power Trac. Could something like that be done? (factory) The only problem I could see is the engine and all the other stuff being in the way. But I think it is a good idea. Even though the PT is already versatile, why not make it even more versatile? Holder and Trackless articulating municipal tractors have a 3pt and PTO setup on the rear with a rear engine so why couldn't PT do it? :cool:
/ Ventrac Assembly Videos #51
:laughing: :)
PT used to sell a 3pt option on some models, if I am not mistaken. Basically, it is just some hydraulic lift arms and a ram for the top link.
One thing the PTs are not good at is pulling. And that is what 3pt hitches are for... pulling dirt plows. I would say if you want to pull a ground engaging attachment, like a plow, you would be better off with a conventional tractor.
/ Ventrac Assembly Videos #52
Agree...
As an analogy, why would you want to put an inkwell, quill-trimmer and sand beside your laptop computer...
/ Ventrac Assembly Videos #53
Ahhh yeah I see what you mean. Being a hydraulic driven machine vs mechanical differentals used by regular tractors, the tractor is more meant for pulling.
Just an idea, though :thumbsup:
/ Ventrac Assembly Videos #54
Yep. It all boils down to gears and gearing. Tractors have range boxes that gear them up or down in high and low range. Some have medium ranges. Some have ultra low ranges, etc... and tractors with gear transmissions have even more gearing options VS hydrostatic tranny tractors.
The Power Trac, on the other hand, has only one range. The factory has to choose a compromise range when they select the size of the engine, hydraulic pump and hydraulic wheel motors. They have to decide if they want high speed at the sacrifice of torque at the wheels or low speed with high torque at the wheels. Or, something in the middle. Moderately good speed with enough power to drive it over hill and dale while operation powered mowers and such.
Since the machine is not designed as a pulling machine, they gave up some wheel torque for better mowing speed while maintaining enough top end speed to get from point A to point B in a reasonable amount of time.
Some owners have opted for larger wheel motor displacement for better torque on hills and such. They have cut their top speed when doing that.
Another owner needed higher floatation in sand, so he had larger wheel motors installed, which cut the top speed, but put on larger diameter tires, which brought up the top speed again and gave him the floatation he needed.
It is all about getting the machine that will do the tasks that you need it to do. It could be a Power Trac. It could be a conventional tractor with gears and a range selector. Heck, it could be a tracked Bobcat. You have to decide what tasks you need to do before you can pick a machine to do those tasks.
2025 DOWN 2 EARTH GOOSENECK TRAILER (A65054)
2025 DOWN 2 EARTH...
1995 Peterbilt 379 Tri-Axle Dump Truck (A61573)
1995 Peterbilt 379...
MILLER BOBCAT 250 PORTABLE ARC WELDER (A64276)
MILLER BOBCAT 250...
2013 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2013 Caterpillar...
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
2006 MAC 35ft. 75yd. Tri-Axle Aluminum End Dump Trailer (A64556)
2006 MAC 35ft...
