ck 30 4x4 stuck in 4wd
   / ck 30 4x4 stuck in 4wd #1
1badwolf
slickhead5465@hotmail.com
my ck 30 has a manual trans, it is stuck in 4wd, checked the lever, it moves freely but will not unlock the front end. problem must be internal, would like to find a service manual or a expolded view of trans to see how big of job this is
   / ck 30 4x4 stuck in 4wd #2
Have you checked the external linkage, maybe got disconnected? Maybe lift the front end up with the loader and see if that helps. Sorry I don't have one, just some thoughts.
thnx for the reply, did check the linkages, took them apart & lubed all pivot points.
linkjage is moving as it should all the way to the side of the trans & that lever is moving,
just not taking it out of 4wd.
   / ck 30 4x4 stuck in 4wd #4
Well if the linkage is connected on the outside and moving freely, then it sounds to me like it has become disconnected inside in some way. :( Should be covered under warranty though. :thumbsup: I believe that there are manuals that you can download so that you can see what has to be done.
Try here for the manual http://www.tractorbynet.com/forums/bobcat-tractors/195831-kioti-workshop-manual-ck25-27-a.html
I hope that you can get this taken care of without too much trouble.
thnx for the info on the address for the manuals, tractor is an '04 or '05 warranty ran out a while ago, (but thats par for the course in my world), thnx again,
2009 CAROLINA  16FT EQUIPMENT TRAILER (A58018)
2009 CAROLINA...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
2013 Infiniti G37 Coupe (A54815)
2013 Infiniti G37...
2017 Chevrolet Silverado Pickup Truck (A55973)
2017 Chevrolet...
2012 Big Tex 14ET-20BK 20ft T/A Flatbed Trailer (A55851)
2012 Big Tex...
