BX25 - Land Pride Box Scraper
/ BX25 - Land Pride Box Scraper #1
Delphicoder
Virginia
Kubota B3200
Hi guys.
I bought a land pride box scraper (the 54 inch wide one). Where the clevis pin goes through the lower arms of the tractor, there appears to be two places you can mount it. On the outside it is a narrow opening, and on the inside it is twice as wide. The manual states to use the bushing (already put together) for cat 1 and cat 1 limited. I mounted mine to the outside, since it seemed to give it more stability (wider mount points). I am not sure if it matters, so I thought I would ask. Here is a pic.
/ BX25 - Land Pride Box Scraper #2
My bb doesn't have that set up, but if it did, that is how I would run it.
Thanks for the info and thoughts. I ran it for a few hours like that, it seemed to be ok. But I am a complete newbie on all of it, even at 70 hours with my little tractor.
/ BX25 - Land Pride Box Scraper #5
I would bet magicheater is spot on with his post. I have begun to buy only LP and Woods implements, but have some bought previously without the clevis type hitches and pulled them with the pins flipped both ways and either works though I prefer the wider attachment points.
I am not a "newbie, but that doesn't mean I am doing it right.
"Wisdom doesn't necessarily come with age. Sometimes age just shows up all by its self" (Tom Wilson)
/ BX25 - Land Pride Box Scraper #6
OK, a box blade is used with the tines up and down, depending what you want to do. I am contemplating next winter and snow removal, box blade or scraper.
My neighbor said he has shoes on his blade to keep it from digging into the gravel. Why couldn't you do something similar to a box blade ? Using one of the tine mounts couldn't you fabricate a tine with an adjustable wheel, one on each side to keep the blades from digging in. Just an idea.
Only thing is the box is square to the tractor where a blade could be angled.
BGBill
/ BX25 - Land Pride Box Scraper #7
BGBill
Gauge wheels need to be behind the implement blade on the already flattened ground. Not before the blade does its work. :2cents:
/ BX25 - Land Pride Box Scraper #8
BGBill
I would imagine if using a BB to clear snow, he would be in reverse. If going backwards, then using a ripper shank mount for a gage wheel would be fine.
/ BX25 - Land Pride Box Scraper #9
My thoughts exactly JD. The wheels would be as close to the center of weight as possible. Regardless of direction of travel they are still going to work, just better backing up.
Would this expand the versatility of the implement.
BGBill
/ BX25 - Land Pride Box Scraper #10
I would not expect them to work very well, if at all when traveling forward.
The box area of the blade is designed to load up with material. That will almost certainly jam the wheels and render them skids.
The 2nd part of the problem, is when going forward the wheels will be traveling over the surface you are trying to level and/or clear of material.
/ BX25 - Land Pride Box Scraper #11
The problem, as I see it, using a 54" box blade for snow. The blade is much to narrow for snow. I use a 5' blade and wish I had bought a 6 footer. I loose to much snow off of the ends of the blade when running it straight, and only cover about 3 1/2 to 4 feet when running it at an angle. I believe my BX23 could handle a 6' blade in snow without any problems.
/ BX25 - Land Pride Box Scraper #12
Box blade... Forward or backward, no tines no wheels.
Box blade... Forward with tines digging.
Box blade... With wheels, Backwards only pushing snow and not gravel. I have 300 feet of gravel driveway. I want to push snow not gravel.
When not needed the wheels would be removed
I would not drive forward through a foot of snow with a box blade, I would back through it. When I would end up with a pile of snow then I would use the FEL to get it out of the way. Wheels would keep blades from digging into the gravel.
BGBill
New/Unused Quick Attach Backing/Mounting Plate (A65583)
New/Unused Quick...
2018 AUTOCAR XPEDITOR GARBAGE TRUCK (A63276)
2018 AUTOCAR...
24 Gauge R Panels (A65640)
24 Gauge R Panels...
Cattle Feeder (A65640)
Towable Pump (A64553)
LAYMOR SWEEPMASTER 400 (A65643)
LAYMOR SWEEPMASTER...
