F2400 front casters
/ F2400 front casters #1
jsh40sw
I am tring to find the proper size tires for the front casters on my F2400. The machine I purchased has two mismatched tires on it now. I have found Kubota part # 76543-42240 but can't find the actual size.
/ F2400 front casters #2
I will check my deck tonight. It is not a f2400 but Kubota has used the same size tire for years.:)
Surprised that one could use any different size as there is very little leeway for any bigger tire to fit.
/ F2400 front casters #3
9x3.5-4. That is the tire size on my 72" deck:D
Thanks for the info. I have one that size and one that is about an inch smaller in diameter. they compensated for the difference by adjusting the the position of the shaft.
Case IH 200 50' Field Cultivator (A66285)
Case IH 200 50'...
2003 NOBLE 12000 GALLON WATER TOWER TRAILER (A65054)
2003 NOBLE 12000...
2019 BOBCAT E45 EXCAVATOR (A63276)
2019 BOBCAT E45...
2004 Suzuki GSX-R750 Motorcycle (A64557)
2004 Suzuki...
2019 Peterbilt 567 Cab and Chassis Truck, VIN # 1NPCX7TXXKD273140 (A65563)
2019 Peterbilt 567...
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
