Dirt moving with my L4400
   / Dirt moving with my L4400 #12
It's an LA703
I wonder what the difference is between the 703 and the 703A, for starters I guess the the lack of under curl on the 703A. Or does the "A" have something to the quick attach/detach model?
Good question. I was curious too and did some googling to no avail. Mine is quick attach.
To be clear, there is a little bit of an optical illusion going on. It is stuck down in a pile of dirt a little bit. It doesnt turn all the way backwards, but it does go pretty far.
french drain
it will turn the corner and go down the hill.
   / Dirt moving with my L4400 #15
Nice work. Looks like the L4400 is doing a nice job. Just curious how you dug the french drain? FEL, BB? Up here we need to go down a lot deeper than that due to frost so it's a BH for us.
Can't help but comment on the nice weather. Up here it's still too wet to do much as all one will do is make ruts and/or get stuck.
In some spots I had to bench it down to get as deep as I wanted to, other spots I hand dug to depth. Over all though I was able to do a large portion of it with the FEL. I wish I had a BH, that would have been a lot easier, but in the end it only took 2 long days start to finish to do 210 feet of 1-3' deep by 12-18" wide french drain. Alone.
1986 GMC Top Kick Grain Truck (A50514)
1986 GMC Top Kick...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
vergenes (A50657)
vergenes (A50657)
2015 John Deere 310SL (A47384)
2015 John Deere...
2015 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2015 Ford F-450...
Case IH 1020 Platform (A50514)
Case IH 1020...
