Howse Cutter PTO
/ Howse Cutter PTO #1
Robcounts
Kubota L3130
I just got a Howse Bush Hog. How do I disconnect the PTO? It does not have spring loaded pin like my old King Kutter.
/ Howse Cutter PTO #2
There are a few different styles out there. Some have a collar that you have to pull back before it will slide off the PTO, some you have to twist and then pull it off.
Kim
/ Howse Cutter PTO #3
KWentling is probably correct, but it wouldn't hurt to get a picture to post.
BTW, did you get a manual with that Howse? Does it tell you anything other then just disconnecting the PTO Drive shaft (that is, more desciption?)
/ Howse Cutter PTO #4
If it has a plastic collar slide it back toward the mower. This will let the balls release from the groove.
/ Howse Cutter PTO #5
My modern ag has the collar you pull back,but it had been sitting on the lot and it was very hard to release . After some use and grease it works as it should now. :) If yours sat outside it could also have this problem.:mad:
/ Howse Cutter PTO #6
We have an older Howse rotary. It has a push pin that has to be depressed that acts like the spring collar that is on my JD MX6.
/ Howse Cutter PTO #7
Yeah...Robcounts (the OP) had that type on his previous cutter, so he knows about the spring loaded pin release.
But that's not what he has on his Howse.
Shouldn't be a surprise though. The implements manufacturers buy the drive shafts and likely don't specify a release type.
/ Howse Cutter PTO #8
I have a Howse also and on mine it has a yellow plastic collar at both ends, while standing over the PTO shaft, i turn it left and pull. here is a pic of a parts diagram for the rest of the cutter in case it is of any help with other things.
/ Howse Cutter PTO #9
Mine rotates counter-clockwise to release the pto shaft. It's bad about rusting if you leave it out in the weather so I have to keep it well greased. Howse likely used many different types on their rotary mowers, they just put on whatever the Chinese shipped them that week.
