JD850 front wheel removal?
   / JD850 front wheel removal? #11
I've loosened lugs about 1/2 turn then driven back and forth in the driveway (not road) to break wheels loose on my truck.
Yup---loosen bolts a little, spray some Liquid Wrench or something good on hub front and back and it came loose for me.
I'd be a little uncomfortable with heat because of the Murphy's Law thing.
   / JD850 front wheel removal? #12
Yeah, which is why I edited the post...
It worked for those Porsche wheels because we didn't heat 'em up much (aluminumn doesn't change color like steel does when heated). Also, aluminum expands at about twice the rate of steel.
However, if you've seen that video (Safety forum a few months ago) of the wheel heated, then exploding almost 2 days(!!!) later...well, it sure catches your attention!!
Maybe we were just lucky we didn't kill ourselves...
   / JD850 front wheel removal? #13
.....However, if you've seen that video (Safety forum a few months ago) of the wheel heated, then exploding almost 2 days(!!!) later...well, it sure catches your attention!!
Yeah, we did enough dumb stuff to fill a book.
On your exploding wheel thing, I was reading in a farm magazine that some larger farm equipment pieces that were made with closed tubing have exploded when cutting or welding on them.
Don't want to hijack this thread but wanted to point out the fact it has occurred. Must be something to do with gasses produced or whatever.
UNUSED Grey Metal Roof Panels (A50860)
UNUSED Grey Metal...
Huffy NEL LUSSO Bicycle (A50860)
Huffy NEL LUSSO...
2002 Fleetwood Expedition 36ft Motorhome (A48082)
2002 Fleetwood...
Redirective Crash Cushion Guardrail (A48081)
Redirective Crash...
2015 Ford F-150 4WD (A51039)
2015 Ford F-150...
2015 Ford F-250 4x4 Liftgate Service Truck (A48081)
2015 Ford F-250...
