At Home In The Woods
   / At Home In The Woods
Wow, I have just skimmed over this thread for the past couple days. I will be going back over much of it. Congratulations!
My wife and I closed on a 40 acre parcel in NW Arizona about a month ago. We purchased a trailer for temporary quarters and plan on building a log cabin. Maybe I should track that project?
Bo,
Have fun on your new adventure. Sounds like your project will have some things in common with ours. I would encourage you to read through my "At Home in the Woods" thread because you should find some information that will help you. I had some quality issues with some of the subcontractors; that's something that every house project will encur. I hope my thread will help you avoid some of the problems we went through.
In the end, I believe we got a quality house. However, if we had not been very diligent at researching building practices and codes, inspecting the work everyday, and getting some advice from TBN, there were some issues that could have gone unnoticed that likely would have caused significant problems with the house down the road after all the contractors were paid and long gone. Contractors and subcontractors don't like the homeowner inspecting their work, for good reason.
Make sure you ask the workers up front how they intend to do things. Also, insist that they abide by all the manufacturer's instructions and the appropriate codes and get that agreement in writing. Otherwise, you will be amazed at what they will try to get away with.
Good luck,
Obed
   / At Home In The Woods #2,972
Dave,
The well guy told my wife that we don't need to cover the the well casing. The water pipe from the well pump runs through the casing 2 ft below grade using a pitless adapter. While building the house, we had a temporary water pressure tank above ground in the well house that needed freeze protection. The permanent pressure tank is now in the basement so we don't need freeze protection at the well casing any longer.
That's a good point about any saplings close to the transformer. We will may plant some shrubs to hide it but will need to consider how deep the roots will grow.
Obed
Ah - Makes sense - I couldn't figure out why you had the concrete pit around the well. Around here, the well head at the surface is just for pump access and the pipe actually goes horizontal 6' or so below grade (usually more to go under the foundation), so it never sees frost.
The power Co guys usually have some spec of clearance they want on given sides of the transformer. If you stick to that with just smaller shrubs, you won't have any issues, but trees could be an issue.
   / At Home In The Woods #2,973
Contact your power company before you plant around the transformer. They have clearance requirements for the safty of their crews in the event the have to work on it.
   / At Home In The Woods #2,974
Here's the picture of our outdoor electrical service panel pedestal where we will eventually install a jack for the future generator.
attachment.php
Hi Obed
Today , after twenty five years, I had some `palmetto` trees planted...Three of them ran where the well , main power, and telephone lines ran....Although I dug the trenches etc. I just could`t be sure where they were after all this time...Make sure you keep hard copies of some of these wonderful pictures you have shared with us. so this done`t happen to you......I was lucky and no wires were broken...The ten palmettos are standing proudly--awaiting a hurricane ---Tony
We don't have a concrete pit around the well; I'm not really sure what a concrete pit around the well is. We don't have any concrete at all around the well. The well was dug 300ft with the drill. The steel well casings were driven down 200+ feet into the well to protect the well from debris. There's not any concrete.
Obed
The heater is not fixed. The next morning it shut off after running 30 seconds. You can get it to work by taking off the grill and pushing a reset button. Yesterday I called the manufacturer. They are going to send me a new thermal overload device and a new grill with larger openings in the grill. The support person said that sometimes the heat from the heating elements causes the thermal overload to trip.
Back in February, I received the thermal overload device and new grill. I replaced them and that helped. The thermal overload device stopped tripping. However, the heater would only heat the bathroom to 70 degrees when the thermostat would turn off the heater. So a couple weeks ago I contacted Broan, the manufacturer, and told them about the problem. I suspected a problem with the thermostat. Broan sent me a complete heater assembly; it has everything except the metal casing, installation brackets, and grill.
This evening I replaced just the thermostat and am testing it. The room appears to be heating up to around 75 degrees now before the heater turns off. Thats better than the 70 degrees we were getting before.
I got curious and put a thermometer at the floor beside the vanity cabinent that is 3 1/2 feet directly in front of the wall that holds the heater. That thermometer was reading 90 degrees. So now I think I may understand the primary issue. The heater is in the wall opposite the vanity that is 3 1/2 feet in front of the heater. The heater blows out hot air which bounces of the vanity wall back toward the heater. The heater thinks the room is 90 degrees and turns off. To complicate matters, we have an HVAC register right below the wall heater which blows hot air during the winter. We picked a poor location for the heater.
I'm thinking that when the temps outside are winter temperatures, the heater may only warm the room to 70 degrees instead of 75. When taking a shower in the winter, 70 degrees can feel fairly chilly when stepping wet out of the shower.
If the heater won't warm the room well enough, we basically have two options. We could relocate the heater to a different spot; unfortunately we don't have a real good location for it. A second option would be to rewire the heater so it can operate in its 1000W (half-wattage) mode per the wiring instructions in the manual. We currently have the heater wired for 240V and 2000W. It might be that in 1000W mode, the heater will not heat up the small area in front of the heater so quickly and will actually allow the surrounding room to get warmer. There might also be a third option. The heater does have the option to be controlled by a remote thermostat. I'm just a little concerned that if we run the heater off a remote thermostat, the heater and the area around it might get too hot. I would have to get the manufacturer's opinion regarding using a remote thermostat. It could be that running the heater in half-wattage mode and using a remote thermostat might be the best solution as long as the heater does not get too warm.
I'll probably test out the half-wattage mode soon and see if that helps.
   / At Home In The Woods #2,977
Obed
Well, OK, but I'm confused. What's this thing that looks like a concrete pit?
attachment.php
attachment.php
Dave,
Those were loose concrete blocks stacked on the ground two high. The well house was sitting on top of the blocks. The blocks are no longer there. We removed them when we removed the well house.
Obed
   / At Home In The Woods #2,979
What do you think would happen if you let the vents on the cover point upward??Tony
   / At Home In The Woods #2,980
Ah. Well there ya go. (I'm Dave BTW). But that was what had me confused. I see now it was something you had done for the camper, which makes sense. Just checking, as these things vary around the country.
You are still on track.
For the FP... Have you checked the moisture content of the wood you are burning? I recall you bought a moisture meter. If you are in for a fight with the stove company, then that is very good info to have. It is pretty typical to "blame the other guy" aka the "wood is wet" in your case. You need to remove those arguments from their repertoire. Of course, the way to do this is:
1. Measure the MC of your firewood on several sticks. Average that out.
2. Call them and tell them your issue.
3. Wait for them to tell you "your wood is too wet"
4. Ask "Well then, What is the correct %MC of firewood to burn in this FP"
5. Ask how you measure that?
6. Destroy them when you say "I used a moisture meter and my wood is measuring 16% with a 2% SD over 25 pieces, all of which I measured just prior to burning."
7. Wait through the stunned silence while the guy figures he needs to escalate....
Seriously, you have seen this in your work life, I am sure. Everyone tries to point the finger at someone else. Predict those finger pointings and cut them off. My guess is they have two options: 1. the wood, 2. the Install. You need to destory them on the first point so they know they are not dealing with Jeb Rube (aka "would you like me to send you the spreadsheet with the %MC distribution vs position on the log including standard deviations and the log normal distribution?" That should light them up :) ). Then have as much as you can on point #2, which they will now home in on. "Cause it can't be their fault...:laughing: The finally ask if they will do the right thing and send out a tech to figure it out and add to their technical knowledge database.
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
CATERPILLAR CB-224C DOUBLE DRUM ROLLER (A52707)
CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED JCT 72" HYD 4N1 BUCKET (A52706)
UNUSED JCT 72" HYD...
Honda 24hp Brush Truck Pump (A57454)
Honda 24hp Brush...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
