top link chain
   / top link chain #1
impdaddy
Gold Member
Omaha, Ne
New Holland 1520
I remember some guys talking about attaching the top link on a rotary mower with a chain to let it float. I need to do that for a spring tooth harrow I bought. Does anyone have pics showing how this is done? As always thanks TBNrs.:thumbsup::thumbsup::D:D
   / top link chain #2
Here is my set-up with my little NH and 4' KingKutter.
   / top link chain #3
Excellent representation there.
But I have to ask why you used a chain since you have the swinging TL bracket on the bushhog?? Shouldnt the swing cover everything except the most EXTREME angles??
   / top link chain
Thanks Jim. I forgot to mention that I am using a Landpride quick hitch and the top link attachment on the harrow is about a foot below where I can attach to the quick hitch. Make sense? Thanks. Sometimes I hate to ask what may sound really dumb, but it is my first tractor and I don't want to screw it up. My tractor is a NH 1520. :D:D
   / top link chain #5
Guess I'm extreme:D
A lot of my hogging is done by backing down over a creek/ditch bank. The cutter drops down and then when I come back up the top link would then bind up. I found I was actually compressing the top link into the back of the tractor. Got lucky, only think I broke was a few lynch pins. Went to this setup and haven't broken anything since. One word of warning. I have caught the front of the mower on stuff and caused the back of the mower to raise up a couple of times. Scares you at first especially when it slams back down. I try to make sure to keep the front of the mower up so it doesn't catch the ground, but once in awhile.....
   / top link chain #6
Guess I'm extreme:D
I guess I just like the way my bushhog 105 is chained.
It is one that uses a rigid TL but the support from there to the tail wheel is a chain.
It would be like taking those two metal straps off you yours and replacing with chain.
This is the second BH I have had like this. One was a Modern Sunshine model (older) and it used 2 1/4" chains on a bit of an angle, almost exactally like those straps on yours. By current older bushhog model 105 just has one single chain. But it is 3/8 chain:thumbsup:
JCB 2145 (A47477)
JCB 2145 (A47477)
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2024 John Deere 6110M MFWD Tractor (A53485)
2024 John Deere...
CFG Industrial QK20R (A56469)
CFG Industrial...
2019 Freightliner M2 106 Johnston VT651 8.5 Yard Street Sweeper Truck (A56858)
2019 Freightliner...
