RTV 500 water temp.
/ RTV 500 water temp. #1
What is the normal operating temp that yall see on the gauge of the 500. I hardly ride mine long enough to get it warm but today took it for a ride and it warmed up and temp would get close and sometimes in the red. Shut it down soon as that happened. Then one time it was headed back the same way and it went back to cool side. I believe I may have a problem with thermostat sticking or something like that, the heater warms up and starts blowing hot air so I believe that water pump it pumping.
/ RTV 500 water temp. #2
If the thermostat is sticking, the heater will start to cool down although it sounds like you haven't run it long enough to find that out...A good thing.
If all of the fluid levels are good, I'd wit you on the thermostat....Make sure that the rad isn't blocked with debris.
/ RTV 500 water temp. #4
Mine goes about 1/8 of the way past cold and never gets any hotter no matter what I do, but my fan kicks on a lot. Yours is running hot for sure. +1 on the thermostat.
/ RTV 500 water temp. #5
Same with mine
just got it back and it was the thermostat, of course on the ride up there on the trailer it must have freed thermostat up because i couldnt get it to overheat it at all but dealer went on and replaced it so hopefully i'm good to go now.
2024 John Deere 561M Heavy Duty Round Baler (A63111)
2024 John Deere...
2005 JLG 2646E2 26ft Electric Scissor Lift (A61572)
2005 JLG 2646E2...
2021 Chevrolet Silverado 2500HD 4x4 Crew Cab Pickup Truck (A61573)
2021 Chevrolet...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
Caterpillar Specification Manuals Vol. 2 Books 1 and 2 (A63117)
Caterpillar...
2015 Ford F-250 Pickup Truck (A61567)
2015 Ford F-250...
