Pictures of toolbox for Grand L
   / Pictures of toolbox for Grand L #1
kub32guy
north eastern Pa
kubota L3240 Dt
Made a shelf and mounted toolbox on L3240, thought I would share some pictures. I was going to mount a metal 16" toolbox with lid instead, but liked this idea better. What do you guys think? tractor toolbox 1.jpg
   / Pictures of toolbox for Grand L #2
Look's good! :) Is the base wood or is that one big chunk of steel. Need more description on how you put this togesther!:confused:
   / Pictures of toolbox for Grand L #3
While looking at you pictures I noticed that you onle have 1 pin in you ROP instesd of both! ????????????:confused:
   / Pictures of toolbox for Grand L #4
Like the tool box, Very nice!
Is the wood that runs up and down the ROPS wiht the plastic ties there to keep the 'shelf' from twisting?
Did you tractor have the tool box behind the seat and underneath where this tool box is mounted?
The base is 3/4" plywood I painted. It is a temporary setup to see how I like it, then I would like to make one up out of steel. I actually don't have either of the pins in I was getting ready to put the canopy down to put the tractor back in the garage. The base is just held to the cross member of the Rops with 2 U-bolts. It's 13" deep and about 30" wide. Any more questions please ask.
   / Pictures of toolbox for Grand L #6
I like it also... Been thinking of getting some thing on my L3240.. Do you have trouble seeing behind you hooking up to equp???
AndyG
   / Pictures of toolbox for Grand L #7
I have a L3540 and my ROP does not have a cross bar there. Mine:tractor: did come with a tool box below and forward of where you mounted your's:confused:
The two pieces of wood running vertically are so the canopy does not push the toolbox when it is down.My tractor does have the factory toolbox behind the seat that still can be accessed by flipping seat forward, but I have never found that box very usefull. I do however have to modify it slightly to use cupholder.:D
AndyG
That was a big reason I went this route, so I could easily remove the bag, just unhook two clips and tool bag is off. It hasn't been on long, but first impressions are visibility is acceptable. We'll see
   / Pictures of toolbox for Grand L #10
UNUSED WOLVERINE TDB-11-66W 66" BUCKET (A57193)
UNUSED WOLVERINE...
UNUSED FUTURE EQUIPMENT SEAT (A57193)
UNUSED FUTURE...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2025 Poly Fuel Tank with Electric Pump (A55852)
2025 Poly Fuel...
2013 Kubota RTV-X900 Diesel Utility Cart (A55851)
2013 Kubota...
