Post Hole Digger Stand
/ Post Hole Digger Stand #1
loghouse511
L.A. (LOWER ALABAMA)
Massey Ferguson 1552
I have a VERY heavy post hole digger 12" auger
Does any one, have a picture of a "phd stand" that you have built, that you can share?Thanks, in advance
/ Post Hole Digger Stand #2
I don't know how to paste the link, but there is a very good thread going on in the "Build it Yourself" section of this forum. Great ideas.
/ Post Hole Digger Stand #3
Hi loghouse :)
This topic comes up a few times a year, you might want to try the "search" function, should be at the top of your page. A search for "Post Hole Digger Stand" or "PHD Stand" or "PHD Dolly" should return lots of threads to read.
Here's a picture to wet your whistle...
Pete
/ Post Hole Digger Stand #4
we just had a heavy duty A frame built to hang our post hole digger on.build it high enough so you can back the digger under it an put the chain on it an hold it up in the air.
/ Post Hole Digger Stand #7
Simple people do simple things. I just back under a tree limb, hook a chain around the digger and un-hook. :thumbsup::2cents:
/ Post Hole Digger Stand #9
I don't use mine much, so I spend 15 minutes to take it apart and lean the pieces in a corner.
/ Post Hole Digger Stand #10
Here's mine, if yours is really heavy you might want to use 6x6 posts and a 4x4 crossbar. You slide the crossbar out, back into place, put the crossbar back, lower the PHD, unhook, then drive away.
Sean
/ Post Hole Digger Stand #11
I had a stand - but now I hang it ....better.
/ Post Hole Digger Stand #12
here's mine , russ
/ Post Hole Digger Stand #13
Sean
Sean
Nice PHD,etc. :thumbsup:
I'am guessing you keep the other half of the PHD pto shaft in the barn.Also judgeing from that knot in your first picture,you were either a sailor at one time or a "professional hangman". :D
Boone
/ Post Hole Digger Stand #14
Sean
Boone
Thanks Boone.. the PHD is fairly old, at least 15 years as far as I know. I got it last spring and overhauled it. It had been dug into the ground for at least two years, maybe more, the previous owner couldn't remember the last time he used it. The exposure to ground and water didn't seem to bother it one bit. I just brushed the loose rust off and slapped a coat of rust paint on the whole thing, put some new bearings and oil in 'er and she works good. Sold under the Kubota name, made by a company in the States.
I don't like leaving the whole PTO shaft on any of my implements, to me it's like leaving the keys in your car.
Sean
UNUSED REMOTE CONTROLLED DUMPER TRUCK (A62130)
UNUSED REMOTE...
UNUSED RAYTREE RMSC78-78" HYD SOIL CONDITIONER (A62131)
UNUSED RAYTREE...
UNUSED KJ 20' BI-PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20'...
500 GALLON FUEL TANK (A62131)
500 GALLON FUEL...
2007 Ford Crown Victoria Passenger Car, VIN # 2FAFP73V67X124782 (A61165)
2007 Ford Crown...
Arrow Quip EF8 Two Bow Alley Kit (A64047)
Arrow Quip EF8 Two...
