Inexpensive mouse trap
   / Inexpensive mouse trap #21
That's pretty elaborate. I just run a wire thru the can and suspend it over the top of the bucket. The way you have it, I wonder if mice in the water can reach the axle and then jump out of the bucket.
   / Inexpensive mouse trap #22
The way that I've seen it and having it work for me was to have a dowel across the bucket and put the can on that dowel.
Not sure if all mice will have the guts to jump for their PB?? :licking::licking:
   / Inexpensive mouse trap #23
I have a similar one and found putting the climb stick to the end of the rolling can so the little beasts can make a short step helps. if you haven't got any soon move to a wall edge a put some light peanut butter scent up the climber. if your in a outbuilding that may freeze or if the bucket can be left for weeks put in some old engine coolant it will keep from freezing of course and tends to preserve the corps so it does not smell to bad:licking: That one is nice my stick just sits there not mounted:thumbsup:
   / Inexpensive mouse trap #24
I use a 1 1/2 inch PVC pipe connector instead of the soup can.
   / Inexpensive mouse trap #25
.......... if your in a outbuilding that may freeze or if the bucket can be left for weeks put in some old engine coolant it will keep from freezing .......
Be aware that antifreeze tastes sweet and kills any animal (like dogs and cats) that drink it.
   / Inexpensive mouse trap #26
OK all, I finally got my mouse bucket built. First night and no mice..hmm wonder if they have too much grass seed hid. Does this look OK or do I need to addjust any thing?
It looks ok as long as the can spins easily. I've always used a stiff wire for the axle and kept it higher in the bucket so they jump over to it instead of down so far, but I think your's will work the same. You'll know if it isn't spinning enough if your bait disappears and you haven't caught anything. I keep my traps right up against a wall though. Mice usually travel within an inch of the outside walls so you'll get more traffic if you set traps there.
   / Inexpensive mouse trap #27
I did not get time to check it tonight. My shop is heated so it does not freeze, no pets get in there. The axle was a 3/8 scap rod, juice can, I tack welded a 1/4" washer each side of the can and left 1/2" clearance so the can rolls very freely. I wondered if I had the can too low or too short of walk way. I can raise the can easy enough if that would help. I have not seen any measurements so I was not sure where all parts clearance needed to be.
I might move it to a different spot.
Those darn critters keep getting in my seed bags and makes a mess then I loose a lot of seed.
   / Inexpensive mouse trap #28
Well I got ONE at this time
   / Inexpensive mouse trap #30
Been using the same basic set-up as the one with two ramps. I put a foam plate suspended on a wire that touches both sides of the bucket when plate is flipped. Put a little peanut butter on both short sides and it will reset when a mouse walks over to get the pb and falls in. Google bucket trap for the plans. Have gone to my property to find as many as ten in the water filled bucket. When I take the mouse soup out and dump it it doesn't stay there to long. That's why I didn't want to use poisons, afraid I'd kill the other animals on my property that don't bother my things. The little guys have ruined a few sleeping bags, have stolen toilet paper, ruined a tarp, made a nest in the hopper of my '28 Economy, and even decided to take up residence in the exhaust pipes of a few vintage m/c's that are stored there.
   / Inexpensive mouse trap #31
An even easier 'trap' along same lines that I used.
Simple 5 gal plastic bucket with hand full of popcorn in the bottom and placed touching my stone fireplace.
No water, just corn kernals in bottom.
Little guys climb the stone face, jump in for lunch and simply can not jump out.
Downside is all you hear is jump-plop, jump-plop for the rest of the night!
Caught something like 70 or so one fall in the old log cabin.
   / Inexpensive mouse trap #32
I use to go to a hunting camp on weekends. We used a similar set up. But we also put a little peanut butter on the ramp. Seemed to help more.
   / Inexpensive mouse trap #34
I usually use a pop can with a ring of peanut butter in the center ... they go after it and the thing spins and drown they go
   / Inexpensive mouse trap #35
ZOMBIE THREAD ALERT - I'm going to try a couple of these. I used Rotel cans, punched holes in opposite sides (to preserve balance) of each end with a regular old-style can "punch" opener. I had to rod out the Rotel pulp with a chopstick. Tomato sauce or beef/chicken broth cans probably would have been better in hindsight, but the Rotel can size seemed just right. Cut a little circular cardboard template to drill EXACTLY in the middle of each end. So the can spins perfectly with next to no effort.
Now for my questions for experienced users:
1) what is the best distance down in the bucket for the can? This seems that it would be critical to prevent mice from stretching out from the up-ramp or the bucket rim and robbing the bait without slipping in. The designs I have seen on the web vary, but typical looks to be having the TOP of the can just below the top rim of the bucket, maybe 1/2"-1".
2) how far should the up-ramp extend past the rim of the bucket, and should it be aligned with the can "axle", or perpendicular to it?
3) would squared off cat litter buckets work fine instead of round? I can't think of any reason they wouldn't.
- Jay
   / Inexpensive mouse trap #36
There is no rocket science involved.
Any bucket, pail or container that is about 18" high with access be it an adjacent wall that mice can climb (wood, brick etc) or a mere board leaning on side of the container to act as a ramp.
As to bait, corn kernels (pop corn) peanut butter etc work great as will most any grains.
For some reason PB seems to be the the all around ideal bait.
   / Inexpensive mouse trap #37
...........For some reason PB seems to be the the all around ideal bait.
Some guy on You Tube swears that TootsieRolls make the ideal bait for snap traps. I stuck them on my traps and on the first warm day, they all puddled. :mad:
   / Inexpensive mouse trap #38
Update: Didn't see anything about distance below the top of the bucket, so I guessed at about 1/2" - 1". Turned out pretty good, I think. I made ramps out of 24" long strips off a 2x4 and placed a single screw about 2" down from one end to hang on the edge of the bucket. This makes for a 2" long "diving board" that is just about 1 mouse length from the nearest edge of the can.
Used a couple of small nuts on each end for "bearings".
Made 5 traps. We've caught several victims so far in the attic and in the in-law's shed where he keeps horse feed. Didn't really expect to catch a lot right now since it is warm and there should be plentiful food outside. But they're built, tested, and ready to go this fall!
Note: If these are used in an attic in the summertime and you don't use antifreeze or some form of preservative in the water, your victims WILL slowly parboil and putrify in the heat. So they still need to be checked every day or two. Else, your wife gets disgusted when she goes to check and empty them! :irked:
- Jay
CATERPILLAR 305CR EXCAVATOR (A60429)
CATERPILLAR 305CR...
2025 HT360W Mini Stand-On Track Loader Skid Steer (A59228)
2025 HT360W Mini...
2006 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A59575)
2006 INTERNATIONAL...
2019 BOBCAT E32I EXCAVATOR (A59823)
2019 BOBCAT E32I...
2015 Forest River Rockwood Freedom S/A Pop Up Trailer (A59231)
2015 Forest River...
JOHN DEERE 544G WHEEL LOADER (A58214)
JOHN DEERE 544G...
