HCJtractor
- Joined
- Jan 28, 2009
- Messages
- 1,541
- Location
- upstate South Carolina, Greenville
- Tractor
- Kubota M6800, Massey Ferguson 240
I am thinking about buying a Miller Bobcat 225 for a welder and also for emergency power to my home. Since this unit is so heavy, I would trailer it. My question is, since I can't get it closer than 60 feet to my panel, is that a problem. I assume if I make an extension cord with the proper plugs, using the right gauge, it should be fine. Will probably never exceed 8000 W. What gauge to use and what is this cord called?
I also thought about buying a good generator and separate stick, but the combo seems to have more advantages. Do you agree? I will only use it for occasional personal use. I would like to have the ability to run my Miller 211 mig and later a plasma 40 or 50W unit. Seems these Bobcats hold their value and they are rated for the mig and plasma, whereas a standalone generator may be questionable. Thanks for any input or thoughts on this. I really need a generator for piece of mind and really want a welder to play with.
