welding table
/ welding table #1
Chain Bender
Kubota L3200
My little welding table is two 1X12's about 25" long and 24" wide (it's ruff cut stuff out of the back yard). It wasn't built as a welding table (it's only 14" tall), it just migrated it's way into my shop and I use it to get off the concrete floor and to keep off my work table off the end of my table saw.
I'm going to build a taller one and am wondering if plate aluminum that I already have on hand will work. I have 1/8" and 3/16" stuff. I suppose I could buy some plate steel, but would like to keep the table light and easy to move around.
If I make a grounding point on the table will the aluminum plate work as a ground well enough?
tks,
CB
/ welding table #2
err. good question. aluminum will conduct a ground and its used in electrical wire.
my welding table is steel because im always banging away on stuff while working on the table. its all 1/4" plate and real heavy.
/ welding table #3
I guess aluminum would work! It would get gouged a lot. Mine is out of steel, I often tack stuff to it to hold things together as I am fitting and assembling a project before final welding. Mine is 1/2" plate
/ welding table #4
I made an aluminum top work bench years ago that is about 4' X 3' and 1/4" thick. Love it. It is my welding and general use bench right now.
I made the frame out of 1" iron pipe legs and angle iron stringers across the top. It also has heavy duty casters that lock and two shelves.
I mounted a vice on it, welded a plug box on one leg with a heavy cord so I can plug the bench in and have a convenient place to plug in a grinder, or whatever.
/ welding table #5
One advantage to having a steel table is that during fabrication you can tack work pieces or supports down to the table when needed. :thumbsup:
/ welding table #6
There you have it.:thumbsup: And nothing like having a perfectly flat welding table.
My table is 1/4 inch steel. The last table I made (not for me) was made with 1/2 inch steel. My fathers was 3/4 inch and 4 ft x 8 ft, he did a lot of welding and big stuff at that.
AGT Industrial M-DGR (A60463)
AGT Industrial...
2023 Bobcat T770 (A60462)
2023 Bobcat T770...
2010 GMC Acadia SL SUV (A59231)
2010 GMC Acadia SL...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
John Deere 995 (A60462)
John Deere 995...
36"x10' Stacks of Sheet Metal (A60463)
36"x10' Stacks of...
