Help with RCK60-24b install on B7510HSD
   / Help with RCK60-24b install on B7510HSD
It does look like his bracket is positioned further from the hose. I wonder if it was customized or came that way from the factory.
Mark
   / Help with RCK60-24b install on B7510HSD #12
Mark
I am not sure i bought this tractor used and the bracket was already installed , if I can take any more or better photos let me know
   / Help with RCK60-24b install on B7510HSD #13
I was able to get a little wrench time in on the tractor today. I removed the mower mount bracket and rewelded the lift arm 1" further outboard. I tacked it first and check clearances, I didn't see any issues. The lift bracket is now directly above the grease nipple similar to " thetooth" pictures. I made a jig out of wood to get the arm welded back on at the same angle. I now have about 3/4" clearance between the hose and the arm mount and about 1/4" to the tube directly above the arm. I haven't mounted the mower deck but will post back if I encounter any problems. Thanks to mdistel and thetooth for the pictures and info. I was able to get a lot accomplished today including -removal of the snowblower, wheel weights,canopy and the rollbar. Next I can start working on retrofitting a Jodale Perry cab I picked up to fit, but will be in another thread.
CATERPILLAR 299D SKID STEER (A51242)
CATERPILLAR 299D...
Quick Attach Pallet Forks (A47384)
Quick Attach...
10 Ft Fork extensions (A50322)
10 Ft Fork...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
2005 Sterling Single Axle Dump (A47384)
2005 Sterling...
2003 Pierce Fire Truck (A50323)
2003 Pierce Fire...
