Clutch Noise???
/ Clutch Noise??? #1
scsims
Central, KY
Mahindra 5525
I just noticed this weekend after I got my tractorback from having the loader and rear remotes installed. I hear a squeaking or squaling sound when releasing the clutch. It's not real loud and doesn't seem to do it everytime or the first several times I release the clutch.
Should I be concerned?
/ Clutch Noise??? #2
If it was me I would check it out. Go over all the linkage connection points and places where the rods may be rubbing. Apply lube. Hopefully that is all it is.
/ Clutch Noise??? #3
Sounds like lubrication to me too, but at least contact the dealer who installed the loader to get it documented...just in case.
/ Clutch Noise???
What do you mean by lubrication? Too Much.... I did grease the throw out bearing recently.... hard to tell if I put too much in or not enough.
/ Clutch Noise??? #5
I'm thinking the linkage. Suggest you run it for a week or two and see if the noise changes (increases or decreases).
/ Clutch Noise???
Linkage? Is this something that I can check myself?
I called the dealer about and he said that he has heard a noise when releasing the clutch on some of the tractors on the lot recently. He said it could be the changing weather causing condensation in the clutch making it squeal.
It's warm today and I was moving some dirt and noticed again. It doesn't do it at first but starts and gets a little louder when using it alot.
Doesn't seem to do it in 1st gear at all.
/ Clutch Noise??? #7
Just to eliminate one possibility, get under your tractor with a can of spray lubricant (I like Fluid Film) and lube the clutch pedal pivot (I'm assuming your clutch pedal is not the suspended from above type). Follow what ever rods, pivots, etc (the "linkage") you see. Spray all pivots. BTW, have a flashlight with you...might need it. Any kind of luck, you'll be able to reach right up to the transmission. DO NOT spray in to any inspection holes you see in the transmission housing!
Then get on your tractor and pump the clutch to work that lubricant in.
This may or may not eliminate the "squeak" you hear. If it doesn't, at least you've eliminated one possible cause.
/ Clutch Noise???
If the linkage made noise wouldn't it do so by just pushing it in and letting out on it without the tractor on?
It only squeals while releasing the clutch when in gear. If it's running but not in gear then it doesn't squeal while degressing the clutch.
/ Clutch Noise??? #9
Good point...
Hmmmmmm...could be the springs on the pressure plate or something brushing up against the clutch, pressure plate. Either of those would likely require splitting the tractor ($$$).
Has it gotten any worse since you first posted?
/ Clutch Noise???
No, and the clutch works fine just squealy.
/ Clutch Noise??? #12
Does your throwout bearing have a zerk fitting so you can grease it? Many of the smaller tractors don't but for those that do, usually one stroke every 10 to 20 hours. Your owners manual would be the correct source for information.
/ Clutch Noise???
Yes, I keep it greased. This started after I got it back from having the FEL installed. Could the extra load on getting the tractor to move cause a clutch problem to arise?
I been searching "clutch squealing" on TBN and some of the results sound like it may be a precusor to the clutch going out.....
I called the dealer the other day and he said it was likly rust from the changing weather and not being used much. I've put a couple of hours on it since getting it back and it still does it. Seems to get a little worse the longer I use it.
/ Clutch Noise??? #14
Well, you could take it to the dealer.
I don't think we're going to diagnose the problem on TBN.
/ Clutch Noise??? #15
I was going to say the hydraulic pump or possibly a change in pitch from your water pump power steering belts. Doubtful if those would make much difference pushing the clutch pedal though..Adding on the new stuff may have stressed any loose bolts where the tractor is bolted together. Go along and tighten anything and everything you can get at.
/ Clutch Noise???
I took off the inspection plate and took a picture. Does everything look good??
/ Clutch Noise???
I sent the below email to the dealer to have documentation in case of a warrantly issue.
"Good Morning,
I talked to you on Wednesday 03/16/11 about a squealing sound upon releasing (engagement of) the clutch with the tractor in gear since receiving the tractor back from having the FEL and rear remotes installed. I ran the tractor for about 2 hours yesterday moving some gravel. When first starting the tractor in the morning it will only intermittently squeal and the squealing seems to get progressively worse the longer I run it and I would think if it was rust it would get better as the rust is worn away not worse.
My concern is that this may indicate the beginning of a clutch issue that may have come to light with the extra load that the tractor is moving with the weight of the FEL. With only 56 hours on the tractor I don’t feel like the clutch would be worn so if there is a problem it must have been initial.
I wanted to send an email in case there is a problem with the clutch we will have documentation of it for warranty purposes.
I’ve also attached a picture of the clutch through the inspection port.
Please let know what you think."
/ Clutch Noise???
The dealer spoke with the Mahindra rep and is going to come out and look at a few things. He said if it's the throwout bearing causing it then it should be covered.
This was posted in another forum that someone else asked about clarifying the issue:
"Quote:
Originally Posted by LD1
What to you mean by "squealing when I release the clutch"?
Does it seueal only when letting the clutch out?
Does it continue to squeal with the pedal all the way out and just driving?
or By released do you mean disengaged? IE: clutch pedal pressed?
Reason I ask is because the throw out bearing should only be spinning when the pedal is pressed. With the clutch pedal all the way out, the throwout bearing shouldnt be spinning. "
"scsims
It is squealing upon engagment. When letting out on the clutch and when the gears begin to move the tractor is when the squeal is heard."
Do you all think that changing from the original 80W API GL-4 oil to Traveler Premium UTF could cause the squealing?
I'm just trying to think of things that happened around when I started hearing the noise.
/ Clutch Noise??? #19
Thanks for the update!
/ Clutch Noise??? #20
I may be out of line here, but if I had a tractor with 56 hrs on it that still made the squealling noise after doing what you have done I would do more than write an e-mail. I would be jumping up and down and letting them know it was unacceptable. In the showroom if necessary.
2016 FORD EXPLORER SUV (A59912)
2016 FORD EXPLORER...
2025 Wolverine MCB-11-48W 48in Hydraulic 4-Way Clamshell Bucket Skid Steer Attachment (A61572)
2025 Wolverine...
2023 CATERPILLAR 299D3 XE SKID STEER (A62129)
2023 CATERPILLAR...
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2013 Ford F-550 Altec AT37G 37ft Bucket Truck (A61573)
2013 Ford F-550...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2017 FREIGHTLINER...
