kubota service cost
/ kubota service cost #1
bigbull338
Elite Member
texas
7040 HDC 1153 fel
well i called my kubota dealer this afternoon to see what the full service cost,an they said between $400 an $500.so im gonna try to get another 50hrs on the tractor before i do anything.they did say that it had break in hydrolic oil in it.an if it got slow or stopped lifting that the oil had gotten to thick an it was time to change it.
well thats what they said.an i guess im a little dumb founded,because i to thought hydrolic oil was hydro oil.ill put another 50hrs on it before i try todo everything.i know the dual air filter doesnt need changing.so thatll save some money.
/ kubota service cost #4
Break-in hydraulic oil? I don't think I would trust this dealer with my tractor. Better (and cheaper) to do it yourself. :thumbsup:
/ kubota service cost #5
As others have said "break in hyraulic oil??".....I'm not a Kubota guy (yet, check back with me tomorrow - tractor shopping!)....but I have been in industrial / construction equipement service for about 20 years and never heard any refer to that before - I guess it's possible - I'd ask to see the sevice info from Kubota on it, though.
I would guess all you really need is a set of the assorted filters and change engine oil after the first 50hrs.
/ kubota service cost #6
Unless a guy is either wealthy or totally inept with even basic tools and has never changed oil in a lawn mower or car before, he should do this himself.
He'll save 50%, familiarize himself with his tractor, and nobody will ever do it as well or as carefully as the owner.
Your manual may state otherwise, but my Kubota B2320 only calls for a simple hydraulic filter change at 50 hours, not dumping all that fluid anyhow.
Engine? yes, oil and filter @ 50 hours, which I think is important.
You sure that guy wasn't just blowing smoke up your skirt, 'cause it sure sounds like that to me.
FWIW
/ kubota service cost #7
Yes, check the manual, I don't think any of the HST's require fluid change at 50 hours and I have never heard of break in oil on these.
We service all of our own tractors and it is not hard.
well im not worring about changing anything on it right now.i questioned them about the hydro fluid.an thats what they said.so i may end up doing all the service on it myself.as for trust issue i trust the dealer.now i have a dealer 15mi away that i do not trust.i havent liked them since they bought the dealership almost 30yrs ago.
/ kubota service cost #10
yeah you should do the servicing yourself, of course you do have to crawl under the tractor and get yourself dirty but its not complicated, i am a total klutz and i do it myself.
/ kubota service cost #11
Keep a cardboard box and break it down or maybe a rug. Lay it on the ground. Get some cheap brown disposable cotton gloves and ............not even get dirty.:D
/ kubota service cost #12
John, my wife and I use to use the brown jersey gloves, but have started using surgical gloves especially while draining fluids. My kids bought me a low slung creeper for Christmas which works pretty well, but will also use cardboard if I have any around.
well all of this is great advice thanks guys an gals.ill wait till my nephews get home as they love doing the oil changing.an the fact that if i lay down under a tractor wont be getting back up for awhile.
/ kubota service cost #14
bigbull, I know you are a lot younger than I, but I have concluded that a small child is about the handiest thing you can have while doing these sorts of things and two are even better. I am good for about one trip down onto my creeper and one trip up. Since we don't gave any kids handy, my wife is my "helper" and she is somewhat less than fascinated with the whole process though she likes saving the money. If your marriage can survive building a new house and/or tractor maintenance, it can handle just about anything.:laughing:
/ kubota service cost #15
Now you're talkin'!!!! There's nothing better than having one the young guys do the work and we do the talking and the pointing and saying, "Good Job".
you got that right,when my nephews come home they have a list of stuff they want todo,so we try to get it done.im used to taking the tractor an doing what i can do alone.an if they are with me i still watch out for them like they was lil lolol.
/ kubota service cost #17
I've got some of the surgical gloves and plan to use them next time. I mentioned the brown cottons because about all Flea Markets have them for 25 to 50 cents a pair. I buy them by the bundle and save a few pennies. One or two uses and they're wore out.
/ kubota service cost #18
Translation
we filled tractor with the cheap stuff thinking you would not notice the difference.....I noticed after doing the 50 hour myself that there really is a difference.
Do the service yourself and if HST or GST use SUDT if it gear just use UDT and that way you know it is done right.
David Kb7uns
/ kubota service cost #19
If the Mx5100HST is like my L3400HST, and I bet it is, you will need for your 50 hour change the Hydrostat filter, the Hydraulic filter and an Oil filter, your engine oil, and a quart or 2 of SUDT to make up for any spilled when you change the hydro and Hydraulic filters. Also calls for chassis greasing several zerks. You dont change out the SUDT Hydraulic/hydro oil until 400 hours. Now I know some guys do actually change out Hydraulic oil at 50, it is up to you, but I am going by what the manual says to do. it is not real hard, dont forget the oil pan (at least on mine) has 2 drain plugs, check your manual, but The SUDT is the same in it now as what you would put in it.. there is no mention of "break in fluid". Good luck
James K0UA
/ kubota service cost #20
..... and a quart or 2 of SUDT to make up for any spilled when you change the hydro and Hydraulic filters .....
I don't know if my dealer used UDT or SUDT when prepping my tractor. Would it be a problem adding the 1 or 2 quarts of SUDT if he originally used UDT?
Massey Ferguson 461 Tractor (A65579)
Massey Ferguson...
2025 Wolverine MCB-11-48W 48in Hydraulic 4-Way Clamshell Bucket Skid Steer Attachment (A64553)
2025 Wolverine...
2004 GMC Sierra 2500HD (A66408)
2004 GMC Sierra...
2004 John Deere 693 Corn Head (A66285)
2004 John Deere...
2022 EZ-GO ELITE...
Approximately 100 Ratchet Tie Downs (A65579)
Approximately 100...
