Brand new kubota question, boot on the powersteering rod?
   / Brand new kubota question, boot on the powersteering rod? #1
ssmith general
St. Clair County, Alabama
Kubota L4400
There is a small rubber boot on the power steering. I have managed to damage these on both sides in one week. I assume I am not the first one, I hope I am describing it correctly. They are not too bad. I am wondering how big of deal this is? seems off to had something that weak exposed.
TIA.
It's 2011 L4400DT
   / Brand new kubota question, boot on the powersteering rod? #2
The boots are pretty tough. Did they rip or just move? The boots are held on by clips at each end. If a clip comes loose and the boot creep? I had that happen in the winter while making a lot of tight turns in 4WD. If that is the problem you can pull the boot back and reset the clip with pliers.
One just came unseated, one ripped a little bit. I am under warranty, I could trailer it up and get them replaced.
   / Brand new kubota question, boot on the powersteering rod? #6
Wow, a lot of effort. How important are these dust covers? Is there a more heavy duty replacement? SHould I make them do it under warranty?
There are various threads on here about fabricating boot guards. As to importance, I know of people who have run torn/missing boots for years. I have to replace one and some day will, but my tractor is still in use.
It is not like a cv boot.
I am sure others will disagree.
That's kind of what I was thinking, the whole joint doesnt seem to be a big deal even if it was in bad shape. Mine are not as bad as those photos. I am going to Kubota today to drool over some forks and grapple buckets, so I will ask someone there how it applies to the warranty. Maybe they just give me the part and send me on my way and I can repacle them when need be? THat would be ideal I think.
Thanks for the info.
   / Brand new kubota question, boot on the powersteering rod? #8
That's kind of what I was thinking, the whole joint doesn't seem to be a big deal even if it was in bad shape. Mine are not as bad as those photos. I am going to Kubota today to drool over some forks and grapple buckets, so I will ask someone there how it applies to the warranty. Maybe they just give me the part and send me on my way and I can repacle them when need be? That would be ideal I think.
Yeah, I doubt warranty will cover it, but the dealer may give you one. I bought a couple because they aren't expensive and since I mow a lot of brush, I will tear another one off.
   / Brand new kubota question, boot on the powersteering rod? #9
Both mine tore off the first month. Been meaning to replace them.
   / Brand new kubota question, boot on the powersteering rod? #10
I may still be meaning to replace mine this time next year.
2006 FONTAINE TH55 SERIES 102" X 42' LOWBOY TRAILE (A51243)
2006 FONTAINE TH55...
2006 BOMAG BW5AS DOUBLE DRUM COMPACTOR (A51242)
2006 BOMAG BW5AS...
2018 CATERPILLAR 289D SKID STEER (A51242)
2018 CATERPILLAR...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
1991 Great Dane 48' Reefer Trailer (TITLE) (A50774)
1991 Great Dane...
