Deutz Parts needed D130 06
/ Deutz Parts needed D130 06 #1
PADeutzguy
I'm working on the final steps of restoration of my grandfather's D130 06 Deutz. Wally & Sabrina at Walts Tractor in Mo have been great to work with, but there are a few things they can't get and may be someone can point me to a parts tractor.
I really need decent working, adjustable 3ph arms. Mine are welded solid, and hooking up to a 5 bottom plow isn't happening.
I'm also looking for the headlights... I know they fall out, but trying to get it back to original. The quick and dirty method is to weld angle stock in the hood and mount TSC lights in there, but welding on that new paint job.. ugh. Pair or not, I'm interested.
If anyone has a roll bar for it... these PA hills are steep!
This one is a "grey belly" it's a 1974, it is the light grey and dark green paint, not the newer spring green models (it makes a difference with the 3ph arms).
Thanks all!
Randy
/ Deutz Parts needed D130 06 #2
Thanks all!
Randy
Is it not possible to get original lights from a dealer.. I have a bit newer ones and just bought some for mine... Maybe you could make a new rollbar for it ?
Good luck!
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2021 Ford F-150 4x4 Single Cab Pickup Truck (A61573)
2021 Ford F-150...
2019 FORD F-150 STX CREW CAB TRUCK (A63276)
2019 FORD F-150...
2021 UTILITY VS2DX 53FT DRY VAN TRAILER (A59905)
2021 UTILITY VS2DX...
2014 F-150 STX (A56438)
2014 F-150 STX...
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
