RaisedonDeere
Is there a 12v power outlet on the JD 2520?
I am confused..My new 2520 has a accessory 12v plug lower right side under the front of the seat..
You do not have to lift the seat it is just down on the right..You are gonna love the 2520..
I want to hear some opinions on this pump. Is it worth the $59.00 bucks? .. Or does anyone have other suggestions for a transfer pump.
Amazon.com: Facet Fuel-It Transfer Fuel Pump: Automotive
The 2520 made between 2006-2008 did not have one. The 2009 and newer ones do. I run a tow behind 15 gal. sprayer with a small 12V pump.
I actually had the cheap cigar lighter plug on the end of the cord start to melt. No damage to the outlet on the tractor, and the fuse never blew. The tractor might not be the limiting factor on how much current you can draw.
I made a tank to hold diesel out of 20'' sch.10 stainless steel pipe,and bought a fill-rite hand crank pump. I can pump 5 gallons in less than a minute. The tank holds 50 gallons. You could use any type of drum,eliminates the gas cans.
Anybody know how many watts or amps the outlet will support? If it's in the owner's manual, I can't find it. Even though I've got a 3720, it's probably got the same DC outlet rating as the 2000 series.
//greg//
