California
Super Star Member
- Joined
- Jan 22, 2004
- Messages
- 16,832
- Location
- An hour north of San Francisco
- Tractor
- Yanmar YM240 Yanmar YM186D
I finally got around to pulling the alternator on the YM186D. It clattered. The seller had told me it 'always sounded like that' and he never got around to replacing the alternator bearings, which he thought caused the racket.
Wow. The good ol ol boy American farmer who owned this, or maybe the guy with a machine shop I bought it from, was as much a hack as those guys who 'rebuild' tractors in VN.
First thing I discovered was the alternator belt was waaay loose. I removed its adjuster bolt to move the alternator beyond the end of the adjustment strap - and the alternator fell off. WTH?
1) the wrong belt is on it, so long that the alternator goes beyond the end of the adjustment strap and is still loose. And 2) the stud into the engine's front cover, that the alternator is supposed to pivot on, is still in place but broken 1/8 inch below flush in the aluminum front cover. No wonder the alternator clattered.
Ok ... so far a wrong belt and a broken stud. I need to pull the battery and radiator to get a straight shot at removing the broken stud.
First, open the coolant drain, the little fitting on the chassis with the tiny hoses. But with a good size wrench on its drain plug and a bigger one stabilizing the fitting - I can't budge the plug. It took a breaker bar. There was no o-ring under the drain plug, just huge torque applied to get a metal to metal seal. Who the heck worked on this thing last?
After the battery and radiator were removed I lifted the alternator out. WTH again! Why does the alternator have a big weld across it??? How do you crack an alternator???? And ... nobody filed down the weld to let the alternator align flat against the front cover! ( I filed it down myself before I took the picture below, and some more later). I wonder if the weld could have stressed and broken the stud.
I went to a first-class industrial supply house for an ez-out and the correct left handed drill, to remove the stud fragment that was still in the engine's aluminum front over. This isn't a place to try Harbor Freight's equivalents!
The left-hand drill bit didn't spin the stud out but at least it didn't tighten it. I'm glad I got a top-quality bit. That stud was hard steel. I hammered in the ez-out and turned it with a tap handle so there was no sideways pull. Finally the stud fragment unscrewed out.
This tractor must have been owned by an idiot. Who would put on a belt so long it couldn't be tightened - then snap the stud securing the alternator. And break the alternator itself?? And not file flat the repair weld on the alternator???
Anyhow, I bought the correct belt (Gates lists this tractor; 33 inch belt), a replacement stud, fresh coolant, and put an o-ring on the drain plug. Everything went back together like Yanmar intended.
I have a question for today's mechanics: I used red (permanent) Lock-Tite to set the new stud in the aluminum front cover. Was that a good idea?
Here's a picture with the new stud in place.
