Just changed my Hydo oil
/ Just changed my Hydo oil #1
Usta
Gold Member
Central Vermont
2008 Kubota BX2660
Changed my hydro oil for the first time with just under 400 hours on the tractor. Changed the hydro oil, hydro filter, and cleaned the hydro screen. I have pulled the screen filter once before but never changed the hydro filter canister. I was getting nervous with all the talk on here about finding metal shaving in the hyro systems screen and filter canister. I looked very close and even played around with a cow magnet but could not find any metal shavings at all.
What really surprised me was how dark colored the old hydro oil was compared to the new oil. The majority of the 400 hours are with hard loader work in the dirt so that may have contributed to the hydro oil heating up and turning dark. Worked the loader real hard last summer.
/ Just changed my Hydo oil #2
Sounds like you covered all of the bases...I usually change mine sooner, so I can't say what fluid looks like at 400hrs...I'm sure it's like tranmission fluid, gets a little cruddy over time, no harm.
/ Just changed my Hydo oil #3
I talked to one of the mechanical engineers at work. He gave me a book with a section on hydraulic oil and strainers that I could almost understand. I think it explains why the oil cracks and changes colors, so I'm not sure the dark color is due to dirt. Here's the text verbatim:
"However, the majority of components of contaminants in working hydraulic systems are not solid particles like ACFTD but toluene soluble resinous matter, as shown in table 2. Resinous matter has polarity and is adsorbed onto metal surfaces. It is sticky and attracts other solid and fiber contaminents which then stick to them. By this mechanism, suction strainers will be clogged.
A suction strainer is actually a full flow filter. Hydraulic oil passes through a suction strainer at very high velocity. This means that both oil and the strainer will be electrified by friction of oil with the strainer. When oil passes through insulated strainers, static electricity will be accumulated on the strainers and the accumulated electric charge will be discharged by sparks. Spark discharge of static electricity will crack oil molecules and produce free radicals. Free radicals will propogate autoxidation of oil and produce polymerized oil oxidation products (resinous matter). This cycle continues, as long as full-flow filters are used in hydraulic systems."
/ Just changed my Hydo oil #4
Heck, I wrote that....ah maybe not...:confused2:
Deano
/ Just changed my Hydo oil #6
Are we to understand that you did not do the 50 hours service, as prescribed? Just curious.
I will go with the manual and only do the filters at 50 hours, as I don't wish to dump all that fluid. However, I have my doubts I'll leave it in for 400 hours. When I get to 200 hours, I'll make a decision at that point.
The new SUDT-2 being synthetic does influence my thinking here a bit, I admit.
/ Just changed my Hydo oil #7
It's only 3 gallons, 20 minutes and $60. I was thinking I'd wait as well but with all the talk about people finding a bunch of shavings (I couldn't find any) and Kubota coming out with the new fluid, I just went ahead and changed it.
/ Just changed my Hydo oil #8
Um...Duh??? Thats elementary my friend....:laughing:
No seriously was that in English?
/ Just changed my Hydo oil #9
I go by the Operator Manuals on all my machinery and see no reason to waste oil etc. We have tractors made in the 50's and 60's still running problem free as well as motorcycles/ATV's made in the 70's that have had no repairs.
My brothers are mechanics and we have tried the more frequent changes as well as synthetics, but now pretty much go by the manuals. For racing or extreme conditions I would use different schedules/oils.
/ Just changed my Hydo oil #10
my tractor is right on the 50hr service time.so im going to have it picked up pretty soon an have it serviced.an then change the oil every 100hrs.
/ Just changed my Hydo oil #11
I change engine oil every 100 hours, but only change HST fluid every 400 which comes out to about once a year or just a little longer.
/ Just changed my Hydo oil #12
ill change the hydro oil every 400hrs or when the book says.but motor oil i change every 100hrs.
/ Just changed my Hydo oil #13
It can be confusing, we have three Kubotas, one Massey Ferguson and a John Deere, so I have to check the manuals to keep track of the service intervals.
It is not a matter of money or time. Just following the manual. I was just surprised at the color of the used Hydo fluid.
In my Operator's Manual - Maintenance Service Intervals, Page 37
Engine Oil and filter
at first 50 hours - 200 hours - 400 hours then every 200 hours.
Transmission oil filter
Transmission fluid
at 400 hours then every 400 hours.
/ Just changed my Hydo oil #15
I seem to remember this being addressed in previous threads, but I can't remember the particulars. The HST fluid in my L5030 never gets dark and it is really hard to get a good reading on the dip stick.
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
2004 Peterbilt (A62679)
2004 Peterbilt...
New 2200lb All Steel Adjustable Gantry Crane (A62679)
New 2200lb All...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
2017 Mitsubishi Fuso FEC72S Landscape Truck, VIN # JL6BNH1A9HK003132 (A65563)
2017 Mitsubishi...
Skid Steer Rotary Mulcher (A65640)
Skid Steer Rotary...
