3 pt multi purpose bar
/ 3 pt multi purpose bar #1
StanR
Gold Member
Houston, TX
Kubota M7040
I saw one of these and thought I could improve on what I saw
So bought a used trailer hitch cheap ... got some more steel
If I keep it, I should be able to do many things with this. Still have to weld the tab, ends etc .. going to use double tabs on the bottom to make it stronger.
This thing is very heavy..
Also made this with some mostly scrape steel I got for free from tractor supply
my deluxe UDS needed a cart with wheels
Got a little more done...
/ 3 pt multi purpose bar #3
Looking good. Are you going logging with it?
Not going logging... Just thought the top bar and chain hocks would be useful around the ranch. Also think it looks pretty cool.
Might have to paint it Kubota orange... to match my mx5100
/ 3 pt multi purpose bar #5
If you are going to pull things that are heavy I think you should brace the lower link pin tabs. I would guess that your MX5100 has enough power to bend those. It is a neat build.
Thanks
I am going to brace them tonight
The tabs are 5/16 x 2.5 inch flat bar.
/ 3 pt multi purpose bar #7
I agree 100%. Your MX will bend those like sheet metal.
I have a similar design on my home-built ripper shank. I used 1/2" x 3" bar and a triangular gusset on the top. I had no trouble bending it even with my little L3400.
I would put a gusset plat on the top AND bottom tying it back into the main beam. Or ditch the single pin and do a clevis style like the HD box blades.
I will add the top and bottom gussets tonight. there should be plenty of room to get a socket in there to tighten
I thought about the clevis style, but this thing is very heavy and thought the single pin would be easier to attached.
I think this might work
Now some grinding and paint
/ 3 pt multi purpose bar #10
Very nice:thumbsup:
/ 3 pt multi purpose bar #11
i was thinking about building one of those to tow my 2-5/16" goose neck horse trailer and 2" bumper pull equip trailer, but on after-thought i think im leaning towards a skid mount receiver method. that way i can be facing forward while i maneuver the equipment into the shed.
i may make my own or buy this one at "quick attach".
Skid Steer Hitch : Quick Attach Attachments, Inc.
not sure if i can make one cheaper.
im also playing with the idea of just adding a gusseted receiver to a set of skid mount pallet forks. but im not sure if the forks are removable. that way all i would have to do is remove the forks and install the receiver. saves about $500 in equipment and 1 less thing to store.
/ 3 pt multi purpose bar #12
Now that looks darn good! I think those trailer mover things are very useful. I made one two or three years ago and I'm still happy I put in the time for that build.
/ 3 pt multi purpose bar #13
I am looking at your picture and I still don't know the answer, so I will ask. What is a UDS and why does it need a cart with wheels?
Google UDS smoker.... They are awesome to use and easy to make.
It needed the cart with wheels because I just wanted to make one..
But it does hold it off the ground :thumbsup:
/ 3 pt multi purpose bar #15
Well done, looks more useful than the trailer mover I bought at TSC, Adding hooks was a great idea.
/ 3 pt multi purpose bar #16
Just be careful pulling a load from the hooks mounted so high up. Once you get above the tractors axle its very easy to turn it over on its back. Happenes all the time. Much better to pull from below or at the axle line.
Chris
Chris
Thanks for the heads up.. I made this for my best friends ranch.. He just sold his gooseneck cattle trailer... so might just put a bolt in the top for now.
Had someone else tell me to run a brace from the top by the gooseneck hitch to where the it connected to the bottom links? Thoughts
/ 3 pt multi purpose bar #20
I would advise that as well. Since on your design, with the hook placement plus the gooseneck, that is a lot of load on the top of your inverted T. And without the lateral bracing, it could easially bend the upright over with any side loads. For example, backing up a gooseneck while trying to turn it sharply. Or pulling with the hook on an angle.
The designs that DONT have any hook-ups on top can ge tby without it, because the weight is carried MUCH lower.
Hope this makes sense. Its getting late:confused2:
UNUSED WOLVERINE HYD SNOW PUSHER (A64281)
UNUSED WOLVERINE...
Deutz F3L914 3-Cylinder Air-Cooled Diesel Engine - 54 HP - Pump Takeout (A63689)
Deutz F3L914...
2025 40in Tilt Bucket Mini Excavator Attachment (A61572)
2025 40in Tilt...
John Deere Gator TX4x2 (A62177)
John Deere Gator...
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
