Hard to start
/ Hard to start #22
I know this may be a stupid question, but have you jumped it to another proven good vehicle when you tried to start it. Some diesels require being spun at a certain RPM to fire, and others are less critical. I have a Dodge Cummins that starts easy in the winter even without the grid heaters. Likewise, my old John Deere [no grids] just needs to barely turn over in the winter just starting on one good battery. Also, when you jump it, you should bypass your battery cables that may be bad and hook the positive directly on the starter, ground to block. I have seen bad cables and bad clamps lots of times. Just an idea, which you probably have already looked into....good luck..!!!
/ Hard to start #23
Here is a link to one tech write up that mentions cranking RPM. Light-Duty Diesel Diagnosis
It is for an older GM truck diesel, but all diesels are the same. As long as the fuel is squirted into the chamber at the right time [ assuming timing has not changed, squirters are in good shape, fuel good, etc ], compression is OK, the thing that matters next is the design of the chamber that the fuel is squirted in. If the motor is not turning over fast enought the compression stoke does not heat the fuel air mixture enough to detonate. Some diesels are RPM critical, and some are not....just life. Not saying this is your problem, but worth looking into. If your motor is one of the ones that needs the RPM, you can crank it from now until the second coming of Christ and she won't fire.
/ Hard to start
Thanks for all the help. Have found two problems to deal with, motor is not cranking over fast enough, and compression is low at about 170,200,160. Will keep everyone up to date as I can.
/ Hard to start #25
Next time you try to start it and she won't start, pull your intake air hose off your intake manifold for a quick try. If you have any blockage [bad filter, mouse nest, collapse of the air intake hose, etc.] it could show up by slow cranking, if it were bad enough. Usually intake blockage will still start but have no power, but wouldn't take long to check.
/ Hard to start #26
Also, I will have to test duration of the glow plug timer in a day or two as the starter seized again for the third time and is currently being rebuilt(again).
You should be able to count to 12 pretty easy before the glow plugs go off but you might also check your cranking speed. Cranking speed is actually pretty critical for diesel engines. The stock battery they put in those things is barely adequate. You will want to make sure all the connections are clean. After a cranking session none of the battery connections should be hot much less warm. Also I haven't checked mine but the timing might be a tad retarded. I know on other diesels that can make a big difference. I can set 6.2 and 6.5 GM diesels by ear. Not sure if the mahindra's have a cold start solenoid that advances timing cold or not. Generally diesels do not run the timing advanced much. You would have to check the mahindra manual to know if it is even possible to change it.
The more the timing is advanced the more it will rattle. A quiet engine is generally a bit retarded.
/ Hard to start #27
Ooops guess I should have finished reading the thread before posting my previous post.
Wow those are some low compression readings. They should be around 400 or so. I have seen totally wore out engines with better compression then that. It have doubled had gasket with only one piston ring?
/ Hard to start #29
I have had 2 mahindras that behaved like this.
We replaced the glow plugs and wire brushed the metal rail that bonds them together, that cured the problem.
Once they are warm, they will start easy, even with the bad glow plugs.
Are you sure you put in the correct glow plugs???
Hard starting when warm is a good clue that the problem likely isn't the glowplugs. Even cranking speed wont matter as much when it is warm. Low compression or timing will though.
2005 JOHN DEERE 4110 TRACTOR (A65054)
2005 JOHN DEERE...
2026 SDLANCH SDLMG1220F Galvanized Metal Livestock Shed (A64194)
2026 SDLANCH...
New Three Point Hitch Trailer Mover (A65579)
New Three Point...
2022 EZ-GO ELITE...
John Deere LX5 5ft. Rotary Brush Cutter Tractor Attachment (A61572)
John Deere LX5...
JOHN DEERE 7420 TRACTOR (A64278)
JOHN DEERE 7420...
