Stump Grinder
   / Stump Grinder #21
I think I've figured it out. The first cuts were in a low traffic area, while the second set were right across the entrance to the parking lot. I suspect that the paving contractor laid the asphalt a bit thicker and compacted it more. It was just harder stuff. It felt kinda like riding a jackhammer.
J_J, now that I'm done with the asphalt cutting abuse, I will sharpen those teeth with a green wheel.
   / Stump Grinder #22
Bob,
Dress up the contour of the face, round square or whatever. The back side of the tooth needs to be tapered from the face edge to the back.
This is a round carbide tooth, but notice the taper from the face to the back.
Thanks JJ.
   / Stump Grinder #23
I have done maybe 20 stumps with my used stump grinder. Maybe i am too hard on it because it never takes me close to an hour; 15 - 20 minutes for ~ 28" stump. The FEL is shaking sometimes when i take too big of a bite. Rotted go the easiest and i do not count those. Green grind pretty well. 6 month old stumps are harder for me to do. My blade is reversed and the welded teeth.
Ken
Ken,
I have the older welded tooth grinder also. I would like to reverse the wheel but I'm a little concerned because it uses chamfered lug bolts and the holes are chamfered. Were yours the same, and if so did you change to regular bolts when you flipped the wheel? Thanks.
Reg
   / Stump Grinder #24
I just reused the chamfered lug bolts. I do not remember if the holes were chamfered or not.
Ken
   / Stump Grinder #27
Be very careful grinding the cutter teeth with the green wheel. Be sure to wear a mask. Cannot remember if it is the carbide or the green wheel, or the combination of both that causes the health issues.
   / Stump Grinder #28
Thanks. I ordered mine and will wear a mask.
   / Stump Grinder #29
Thanks for the reminder. I had heard that, but I probably wouldn't have remembered.
   / Stump Grinder #30
Is that the same for the Pink wheels you use on chainsaws? Man, I am a dead man given how much bad stuff I have inhaled.
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A56438)
2008 Ford F-250...
Mini Excavator Hydraulic Thumb (A55272)
Mini Excavator...
Mini Excavator Quick Coupler (A55272)
Mini Excavator...
2012 KUBOTA KX080-3 EXCAVATOR (A52709)
2012 KUBOTA...
2009 Ford F450 XL Utility Bucket Truck (A55272)
2009 Ford F450 XL...
2007 Kenworth T800 Tri Axle Day Cab Truck Tractor (A56858)
2007 Kenworth T800...
