Loader Mounted Blade Build
/ Loader Mounted Blade Build #1
wvpolekat
Buckhannon, WV
1947 Ford 2N and 2003 Kubota B7500
DISCLAIMER: I fully realize that this does not have any trip mechanism and could result in any number of broken/bent items on my tractor and personal injury to myself including cancer of the eyelashes. I accept this risk because I know how this will be used and under what conditions. To me, the owner of said tractor and attachments, this is an acceptable, calculated risk. Please do not turn my build thread into preaching about this. I am well aware of it.
Just wanted to share my latest project which is a loader mounted blade made from my rear blade. The blade will be also be able to be converted back to a rear blade. It's primary use will be snow removal. If I need to move dirt, I will mount it back on the rear of the tractor.
My design was inspired by zmansmac. You can see his blade here and here.
I did not take as many pictures as I would have liked, but I will describe things as best I can. It really was a pretty simple build.
Parts list:
Approximate cost not including tractor or blade: $100
Tools Used:
  • Oxy/Propane Torch
  • Hobart MIG Welder
  • 4" angle grinder with various cutoff, grinding and flap wheels.
  • Assorted hand tools. Hammer, Punch, etc.
The first step I took was to cut the main beam of the blade approximately 10" from the blade pivot. I wanted to keep this as short as possible because this will determine how far in front of the loader arms the blade will be.
After cutting the blade off, I turned to the loader mount. I first cut the 3x5 to be the same length as the distance between the outside of the bucket mounting brackets. I used the angle grinder for this to get a clean cut without grinding after using the torch.
Next up was the mounting brackets. These were modeled after the mounts on the back of the factory bucket. They were then cut from the remaining 3x5 steel tube. Lacking a 3/4" drill bit, the pin holes were cut using the torch in the skilled hands of my ex father in law who was helping me. They are not 100% clean, but the plan is to add 3/4" ID bushings like the factory brackets eventually.
Here is one before making the holes
After mounting the brackets on the loader arms and making sure the pins aligned properly and we had full range of motion, the beam was clamped in place and tacked. Range of motion was once again verified without binding, it was removed for final welding.
Here it is on the loader arms:
We had found that a 2.5" to 2" receiver hitch adapter sleeve fit perfectly inside the beam on the blade. This would also allow me to use any 2" receiver hitch pieces on the loader beam. One of these will also be used to rejoin the blade to it's 3ph frame. Added bonus is that it turns the 3ph frame into a 2" receiver hitch when the blade is not attached. It could be easily used as a starting point for any number of things.
Because of the short length of the sleeves we had available, we had to surface weld it to the beam. Ultimately, this proved to be a bad choice. During testing, it quickly broke off. I am getting a longer piece of 2.5x.25 square tubing and it will be run through the beam for much greater strength. Maybe it was a bad weld, but it was obviously the weak link. Unfortunately, I did not get a picture of the blade mounted before the weld broke.
Here is the broken weld, to me it looks like it had almost no penetration. I have had lots of things welded by him and never had a problem. Either way, it is what it is.:
Still to do:
Fix the broken weld with something stronger.
Add power angle. I have most of the parts for this, but it was just not a priority at this time.
Thanks for reading. Comments and suggestions welcome. UNLESS THEY ARE ABOUT THE LACK OF TRIP MECHANISM.
/ Loader Mounted Blade Build #2
Its missing something that zman has. Wheels.
Wheels or skids would allow you to raise the blade so its just above ground level and would not dig into a gravel drive. I dug a huge ditch into my driveway with my truck plow last week while trying to move a pile of snow and ice. If the shoes/skids were on it would have done much less damage.
Wheels would allow you to float along without to much effort or drag either.
And while you don't want to hear anything about trip edges, wheels or skids might help you avoid needing them. If you were to angle your blade so that the cutting edge was leaning forward slightly (top of blade significantly forward of the bottom edge) and added wheels or skids to the back side for support and repeatable angle, you would ride over small obstacles. Larger ones like stumps would stop you dead though. But then again it would stop any blade dead.
I'm thinking three castor wheels, two on the blade and one behind the mounting beam, to be set level with the blade down. Make them removable and height adjustable. I would use solid core or foam filled tires for these. Air filled tires might flex to much and let the blade dig in.
The only sacrifice would be that you won't be able to scrape clean to the pavement surface.
I am undecided about wheels right now. I don't plow gravel surfaces, only smooth asphalt and concrete. So, digging in is not much of a concern. But, the option is still there, will just have to see how it works. I really want to be able to scrape all the way down.
Got the bits to fix it today. Going up Sat morning to hopefully finish it and get some pics of it all assembled.
Going to try to get the cylinder mounted too.
New pictures.
I got it all assembled and working with power angle.
I had one slight problem. When I put the receiver tube through the cross beam, it was right around 1/8" out of plumb. This ends up being about 6" at the end of the blade. So, it does not sit flat on the ground. I have the parts to fix it and and give it rotational float as well to conform to the road better.
I am going to split the "stub" right where it comes out of the beam and insert a 2" round bar as a pivot with a pin to lock it level and some chains to limit it's rotation.
Now, for the pictures:
Here it is from the front, of the ground, you can clearly see that it is not level.
Here is where the stub goes into the beam from the rear blade. The new pivot will be in the black section to the right of the blade beam.
Here is where the angle cylinder mounts to the loader beam.
Here is where the angle cylinder mounts to the blade. It is a weak mount on purpose. The hope is that it will give way if something is struck.
I have a video showing complete range of motion that I will upload later.
/ Loader Mounted Blade Build #6
Hey, you do realize there is no trip on that blade and you could really screw things up.:laughing::laughing::laughing::laughing:
Seriously though, nice looking build. I am looking forward to some pictures of it in action:thumbsup:
But maybe next time, resize the picture a little smaller. I dont know if it is just me, but they took foreeeeeeeeeeevvvvvvvvvveeeerrrrrrr to load. I am on the computer at work and while it isnt is fast as my RR at home, it is by no means sluggish and I still had to wait a good bit.
For pics on the internet, there is no reason to go much bigger than 600x800 which will give you ~ 100kb picture. No need to upload massive pics.
And if you did resize them and the internet just had a little hic-up here, I do apologize. But pictures usually load MUCH quicker than these did.
EDIT: I just checked and the pics are indeed 5MB + EACH. That is about 50x's larger than needed.
I dont meant to sound grouchy, and I do look forward to more pictures, but.....
If you dont know how to resize, just ask. There are a ton of us on here who do it all the time and can guide you through it. Downsizing makes browsing and reading much more enjoyable for everyone.
/ Loader Mounted Blade Build #7
X2 about the big pictures.
That's a very heafty looking blade set up. You've done good work. I'm jealous. I have a blade that I intend to mount to my loader (or in place of it) someday, but I haven't gotten around to it yet.
I'm eager to see your rotational adjustment solution. Looking forward to more pictures.
/ Loader Mounted Blade Build #8
I did just take a closer look at some of the pictures.
I do see a potential problem.
It has to do with your cylinder mounting, or more precisely, how close it is to the center pivot of the blade.
I think it may give you problems when plowing with the blade angled and trying to windrow. Given the extreme leverage the blade has over the cylinder, if you dont use a PRV, you will be constantly blowing hoses. If you do use a PRV, you will have a hard time keeping the blade straight. And even though you designed the mount to be a weak link, I think the hoses will pop first.
There have been a few posts where this has been covered in detail. I'll try to find a link. But the math is simple and if you can take some measurments, that will help vs trying to guess.
But this will give you some Idea:
It appears your cylinder mount is about 4" away from the king pin of the blade. The edge of the 6' blade would be 36" from the king pin.
That is a 9:1 lever ratio.
Assuming here: 2.5" cylinder and 1.25" rod
It would only take 1600lbs of pushing force on the one edge of the blade and 1200 on the other to develop 3000PSI in the cylinder and hoses. Depending on which way it is angled. (collapsing the cylinder will take more force than trying to extend. Meaning a cylinder had more push force than pull).
Developing that kind of force isnt hard to do when pushing.
Especially if you catch a curb, get a good bite, catch the edge of sod, etc.
Since you already have it built, try it and see how it performs. But if I becomes an issue, I'd go to a longer cylinder that way you can move the pivot fathrer from the king-pin. And a larger diameter cylinder will help as well.
/ Loader Mounted Blade Build #10
Judging by the background in the pictures I don't think that you will have enough snow to worry about a trip mechanism, but you do have a lot of leverage working against that 2" receiver...You might have to stop in a hurry (before running over the blade) if something lets go.
/ Loader Mounted Blade Build #11
I think you have a fair chance that you will bend the blade at the exact point where you welded that hydraulic cylinder mount. It will be an easy fix though to add some "beef" to that.
Other then that I would use trip springs.........:thumbsup:
:laughing:
Point taken, but I happen to have that cylinder laying around. So, I used what I had. I did intentionally run it into a stump at the furthest corner enough to significantly flex the blade with no apparent ill effects.
I think we are done with snow for the season. But, the project just happened to come together when it did. Will be ready for next winter. It will be a work in progress I am sure.
/ Loader Mounted Blade Build #13
Mark,
Looks like a nice job. Happy to see that I inspired you and I hope this design works as well for you.:thumbsup: I sent you a separate PM about Easygo's concern and he is absolutely correct. To connect my angle cylinder to the blade I used a piece of 3/4 stock, 3 inches wide. I thought this was substantial welding it directly to my 6 foot Land Pride blade which is 1/4 inch thick. But at some point I bent the blade with the angle cylinder. So as I mentioned in the PM you would do well to first weld a larger plate on your blade at this point to stiffen it and spread the load especially since it appears your blade is even wider and perhaps not as thick. To address the other remarks about the gauge wheels, I have them to plow the gravel part of my driveway without tearing it up. I can also plow a path back to the mulch pile for my wife without tearing up the "grass". The gauge wheels were placed to allow the edge of the blade to be as much as one inch off the surface. And I can tell anyone from experience after several replacements/repairs that if you want to use gauge wheels on a project you're better off spending a few more bucks and getting the solid rubber tires.
JohnZ
B7500
Ok, I will look at beefing up where it attaches to the blade as well as a relief of some sort.
But.... The powers that be smiled on me today and we got enough snow to plow!
It works very well in about 2 inches of VERY wet slush. I was able to do most of it in 2wd.
Only issue is the tilt that I knew of before hand. But when angled to the right, it cancels most of it out. But, it still needs to be able to float to conform with the road. Once that is addressed, I will be pleased.
Over the last week or so, I have been carefully watching my road for any possible danger spots and identified 3. None very bad. It was able to glide over them with no issue.
It is fairly sensitive to "curl" angle and that greatly impacts how well the snow rolls off the side.
/ Loader Mounted Blade Build #15
I think your project is interesting and will work quite well once you work out the kinks and get used to what is the best way to use it. Besides when the snow melts you can convert it back to a rear blade and fix the trouble spots in your road.
/ Loader Mounted Blade Build #16
Is it just me ?? I still haven't been able to review the pictures ... they are BIG and I can't resize them, I have to scroll right to see them and then back left ...
Images have been resized to 1024x768. Sorry about that.
Anyhow. Started work on the rotational float assembly. At least as much as I could do at lunch. Which wasn't much.
First, I cut the "stub" off the loader beam.
The picture shows the 2" round bar where it will live and the blade will rotate:
Here it is with the remainder of the stub slid over the round bar. I still need to clean up the cut to make sure things move smoothly:
Still to come:
The round bar will be welded to the blade side of the stub and then I will do something to keep it from pulling out of the portion in the loader beam.
I there will also be a tab welded on the portion of the round bar between the sections of the stub. I will use that with chain to limit how much it can rotate.
Will more than likely fill the the moving part with grease as well.
I had to quickly scab it back together because of unexpected snow in the forecast. It piviots, but I am not real happy with it right now, needs more refinement.
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A62131)
UNUSED WOLVERINE...
Ag Leader Integra Screen (A63116)
Ag Leader Integra...
2023 RIPPA R360 EXCAVATOR (A62129)
2023 RIPPA R360...
2015 CHEVROLET 2500 HD CREW CAB FLATBED TRUCK (A62130)
2015 CHEVROLET...
(20) 1/4"-3"X4"X20' TUBING (A62130)
(20)...
2009 Kubota RTV900 4x4 Diesel Utility Cart (A61567)
2009 Kubota RTV900...
