making knives from odd steel
/ making knives from odd steel #31
Look up "black smithing" on the web. I don't have it book marked, he goes into tempering and most all forge work.
RR spikes are a step up from mild steel, will make a good knife that holds an edge. Early "Buck Knives" were all made from old files. The plant was just up the street from my business in "El Cajon CA". Stopped in a few times and watched them work
In refference to the earth forge, a forge does need a grate to hold the fire on and allow air to blow through it.
If you build a forge out of a barrel or water tank, weld a 2" pipe "T" under the grate area, put a sliding gate on the bottom and a short pipe going out. Attach a flex hose to it. The gate will let you control air flow and clean out coals that fall through.
My old forge is still a hand cranker, sure keeps you busy, cranking & forging. Will put a vacum on it some day.
Will be posting and article with pictures on forged hooks, "T" hooks and other fun toys.
ditto that for sure!
/ making knives from odd steel #33
My parents moved to Alaska in the Fall of 1965. Someone gave my Dad a heavy piece of an industrial hacksaw that simply had a lot of black electrical tape wrapped around one end for a handle and then one edge had been sharpened for skinning moose and caribou. Dad said it was hard to sharpen, but when sharpened would hold an edge better and was a better skinning knife than any store bought knife he'd ever tried. I wish I had a picture of what looked like a piece of junk, but I don't. Anyway, in the mid-70s Dad gave it to me. I really had no use for it, but a neighbor friend took it and worked on it. I still have it and the photo is what it looks like today.
It just dawned on me that I said "hacksaw" when that was a heavy "file", not a hacksaw blade.:eek:
/ making knives from odd steel #34
I have made a few fillet knives from German hacksaw blades that we used to use at work. they were about 1/8" thick and made good knives.
I have a very nice knife that a friend of mine made. He made it out of an old sawmill saw blade. He made some very nice knives and sold them for $125 and up.
/ making knives from odd steel #35
To forge steel, you need to heat it up to bright red-pale yellow heat. You cannot get to those heats in a BBQ grille. To Harden steel you need to heat it up to approx 1500 degrees F. or critical temperature, and then quench and temper. Generally tempering temps are in the vicinity of 400 degrees F. You can play with a BBQ grille, but you won't make a suitable blade.
Old files can make a good blade if you anneal them first, forge, shape, and
finish, then heat treat. Good, old files (Nicholson) are usually W-2 steel which
will make a good knife, if properly heat treated.
Railroad spikes are more or less mild steel, unless you get ones which are marked "HC".
The "HC" spikes can be hardened to make a suitable blade.
Bill Hoffman
Apprentice Smith, testing for journeyman this year.
American Bladesmith Society
i don't recall anyone mentioning forging in a bbq grill.
soundguy
/ making knives from odd steel #37
Post #8. BBQ grille won't get hot enough to normalize and anneal steel.
It might be ok to temper.
/ making knives from odd steel #38
I've made crude ones out of power hacksaw blades. I was more interested in function than form and wanted to use them because they were cheap(free).
I have done that with sawzall blades and 1/2" copper pipe. Works great for a saw.
Aaron Z
/ making knives from odd steel #39
I have a 13" planer with disposable blades (two sided). I save the blades after they are not usable in the planer and make blades out of them for use in the shop (like gasket scrapers) They would make a dandy small knife with some cool vent holes in the middle!:cool:
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
WATER TRAILER (A58214)
2018 Peterbilt 320 EZ Pack 40yd Front Loader Garbage Truck (A59230)
2018 Peterbilt 320...
2015 Sealine F380 Flybridge Motor Yacht Boat (A59231)
2015 Sealine F380...
2013 MACK CHU (PINNACLE) (A60736)
2013 MACK CHU...
2018 Ram 1500 4x4 Crew Cab Pickup Truck (A59230)
2018 Ram 1500 4x4...
