hydraulic hose replacement
/ hydraulic hose replacement #1
jpat34721
Member
Sonoma County (California Wine Country)
MF 1260
I need to replace the hydraulic hoses on a MF-1246 FEL. These are the flexible hoses which go to the joystick valve. I've never done any hydraulic work before. What is the procedure? Do I need to relieve the pressure first somehow? After replacement how do I bleed the system? Any hints would be greatly appreciated.
Jeff
/ hydraulic hose replacement #2
Turn Machine off. Lower loader so no pressure. Unscrew Hose. Take it to your local hose shop, Napa or one of our online sponsors. They can make they any length. Super Simple.
/ hydraulic hose replacement #3
G'day as racerboy said lower to the ground turn engine off and operate joystick in all directions until no movement then take the hose off, to bleed the system just cycle it through it's full range eg right up/down, curl/tilt three or four times and the system will bleed itself
Jon
/ hydraulic hose replacement #4
...and then check the sump to add any makup oil needed to bring back up to proper level.
soundguy
24in excavator tooth bucket (A61307)
24in excavator...
(INOP) WHITE 2-180 TRACTOR (A63291)
(INOP) WHITE 2-180...
BARRY HILL 20 GALLON ALLY WAY SPRAYER, 3PT (A63291)
BARRY HILL 20...
2021 John Deere HD35R Draper Head (A63111)
2021 John Deere...
Rotary Brush Cutter Tractor Attachment (A61572)
Rotary Brush...
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
