DS3510 2011??
/ DS3510 2011?? #1
Kiotikarl
Gold Member
Quebec Canada
2010 Kioti ck30 gear
Hi everyone, just looked at the kioti web site, a new DS model will be arriving soon; DS3510. Anyone know anything about this?:confused:, the kioti web site has no info on it.
/ DS3510 2011?? #3
what do you want to know about the ds3510
/ DS3510 2011??
Everything, hydralic output, pto hp, size/dimensions, tranny type, etc. Looking to possibly upgrade my ck30 to something with a little more power, and this is a new model, just want a little info.:D
/ DS3510 2011?? #5
DS3510///35HP/PTO27.6/==CLUTCH;2 STAGE,DRY//TRANS/8/8==PTO,LIVE==PUMP,GEAR/TANDERN==PUMP/FLOW RATE 12.7GPM===3PT LIFT CAP/2238LBS==OVER LENTH,113IN/OVERWITH,51.7IN=OVERALL,HEIGHT/TOP OF ROPS/88.6IN==WHEELBASE,64.6IN =MIN GROUND CLEARANCE,10.8IN==WEIGHT W/ROPS,2900LBS===IT LOOKS LIKE YOUR TRACTOR/THE SHUTTLE IS BY YOUR LEFT LEG //THE SHIFTER IS ON THE LEFT SIDE OF THE STEERING WHEEL//HAND THROUDLE IS A TALL STICK FROM DOWN BY THE BRAKE PEDALS. I JUST GOT ONE IN THIS MONDAY OVER ALL I THINK IT IS A NICE UNIT.HERE IN OKLAHOMA. GOTTA GO TIME TO GO HOME.
/ DS3510 2011??
Thanks for taking the time to hand in these infos for me. Now i just have to make up my mind on what to buy, the DS3510 which appears to be the same size as my CK30 is interesting. By any chance, would you know what the loader model will be.
/ DS3510 2011?? #7
THE LOADER MODEL FOR THE DS3510 IS KL352 THE LIFT CAP/IS 1155LBS//BREAK OUT FORCE IS 2046LBS
/ DS3510 2011??
In other words, it's an economic model of the ck35, but with a hydraulic pto, and the shuttle is not full sync.(have to come to a complete stop to change direction)
/ DS3510 2011?? #9
yes you have to come to a stop to switch shuttle //also i forgot to mention it does not have a flat deck you have to step over the trans housing not like ck30/35:(:(:(
/ DS3510 2011?? #10
Just drove in from the airport coming from the meeting. The PTO is manual, the chassis is one of KIOTI's oldest designs, tired and true. the 4wd engage is also manual. This tractor is the replacement to the LK30 and has the same chassis, but wiht more HP and CK style hood. it will cost less than a CK30 and have more HP and a stronger loader. the loader is comparable to the loader on DK35SE except with the joystick mounted to the loader frame. I will post some pictures.
/ DS3510 2011?? #11
OK, these are not the best but here they are ds3510 first look at dealers meeting reception. I now realize I didnt take any of the whole tractor in teh daylight during the ride and drive..
/ DS3510 2011?? #12
those figures seem to be from the CK loader KL130. I would think the DS3510 would have a loader almost identical to the KL351 which has lift capacity in the 1400lb range as I recall.
/ DS3510 2011?? #13
Looks to be a nice basic tractor. I like what Kioti is doing there.
/ DS3510 2011?? #14
Hey thats 2 tractor in 1!
That is the CK35 hood on an old LK tractor frame.
/ DS3510 2011?? #16
So its a STEALTH tractor!?(refer to pics). Meant to be used at night only so as to not burn up daylight?:laughing:
