FEL problem on my JD. Need help
/ FEL problem on my JD. Need help #1
al20hp
Member
Jd 4700
When I go to dump the bucket on my JD 4700 460 loader the lever sticks to the dump position and does not return to the middle"neutral". So the bucket continues to dump unless I move the lever back to the middle. Any idea why this is doing this??? When I go to raise or lower the bucket etc. And let go of the control it springs right back to the middle with no problem Thanks for the help in advance
Al
/ FEL problem on my JD. Need help #2
Have you tried to lubricate all the linkages between the joystick and the valve? That is the most common problem with what you describe. Fluid Film works great for this since it last's a LONG time.
/ FEL problem on my JD. Need help #3
Could the up/down and curl/dump functions have been swapped so that you are actually "stuck" in a FEL float position?
/Marcus
2021 POLARIS RANGER XP1000 RTV (A65054)
2021 POLARIS...
UNUSED JCT 74" HYD VIBRATORY ROLLER (A65055)
UNUSED JCT 74" HYD...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
2009 Volkswagon Jetta Sedan (A64557)
2009 Volkswagon...
2009 Dodge Charger Sedan (A64194)
2009 Dodge Charger...
HONDA Plate Compactor (A64557)
HONDA Plate...
