Like having a start button, but not cool.
/ Like having a start button, but not cool. #1
jcims
Gold Member
Ohio
I was 'dismounting' yesterday and my key got hung up on a jacket pocket:
The rest is buried (invisibly) in the tumbler, so i can just twist it with anything that will grab the key slot. Any of you smart fellers have a suggestion for avoiding a replay of this in the future? This isn't the first time the key has hung up on my clothing.
/ Like having a start button, but not cool. #2
Operate your tractor neked.:laughing:
/ Like having a start button, but not cool. #3
/ Like having a start button, but not cool. #4
Jcims
Bobcat makes "short" keys that will help. I was catching the ignition key and knew that I would eventually break it off. The short key has about half the body of the standard key and makes a significant difference. You still have to be careful but it should solve your problem.
Fred (CT235)
/ Like having a start button, but not cool. #5
Do you have total control over the machine, is it on your property/ farm.
If yes then you could install what every army jeep had a ignition switch on the dash. This is really what you have now, the honour system.
If you are on a job site well then what I have seen is a lockable steel cover over the ignition switch.
I have seen ads for a new car with a push button start switch and you could relocate the master switch out of harms way ie ( your jacket/ clothing).
I was not the biggest help.
Craig Clayton
/ Like having a start button, but not cool. #6
Been there, done that, took a couple of picks and dug the buried part out and started using my spare key. Reminds me I need to buy a couple more keys, lol.
(honor system, when all of JD keys are the same doesn't matter)
David from jax
Fred Barbour said:
Jcims
Fred (CT235)
Going commando, i like it...no short key jokes, please. :)
Fortunately it's on my property and sleeps in the garage. I lobbed a note over to the dealer asking about better keys, but knowing for certain will help (that or a dremel). I haven't tried digging it out yet, may give that a shot when it warms up a bit.
Thanks again folks!
/ Like having a start button, but not cool. #8
A broken coping saw blade will usually extract the broken end from the switch. You could make a switch guard?? i.e. A bent U or L tab that mounts over the switch retaining nut like a washer with side(s) to shield the key. MikeD74T
/ Like having a start button, but not cool. #9
last time i broke key off the best thing i found to dig it out was the key ring. it was thin spring steel I straightened out and made int a pick. Maybee some wd40 would help.
/ Like having a start button, but not cool. #11
I also second the short key. It has helped me alot.
I did look at the switch for the lights I believe or the signal I can't remember. Anyway its on the left side and it sticks out. I think I am gonna hacksaw it flush just where I can operate it before I rip the whole thing off accidentally. That little plastic housing around the switch is prollly like $647.56 from the dealer!
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
Adams 8 Ton Blender (A63689)
Adams 8 Ton...
Mini Universal Wheel Barrow (A65640)
Mini Universal...
EZ-Steer Controller and EZ-Steer Motor (A65640)
EZ-Steer...
More info coming soon (A61574)
More info coming...
1984 Mack MS250P Fuel Truck, VIN # VG6M114B1EB080951 (A65563)
1984 Mack MS250P...
