M8540 or 9540
/ M8540 or 9540 #1
dieselbill
2011 kubota L5740 grand cab with loader
am looking at these two but would like to know how wide it is with both
18.4 30 and 16.9 34 because 78in is the widest i want to get and if any one
has the 12x12 speed chart i cant find it anywhere just 8 or 24 speed thanks
/ M8540 or 9540 #2
I will look at the manual and get back with you, our tractor is at another farm right now. We had ours set wide for stability on hills.
/ M8540 or 9540 #3
I don't know if you can get down to 78 in.
Are you going to run a loader.
E/S
/ M8540 or 9540 #4
Page #2 of my Manual gives the minimum tread width of 78" for the M8540 and 79" for the M9540. These dimensions are with the "standard rear tires which for the M8540 are the 18.4x28 and for the M9540 18.4x30. Our tractor has the 18.4x30 tires.
I don't have any way to copy the speed table.
/ M8540 or 9540
I do plan run a loader with a 8 foot snow blade and when u fully angle it is only 84in wide and some snow will role back in and i dont want to pack down with the rear tire. i drove a 7040 yesterday and 8 speeds are just not what i want for snowblowing but i don't know if it is worth the six grand to from a 8540 12 speed to 9540 dual speed 24 that 6k will pay for the snowblower
The Price i got M9540 HDC24 fel cast rims 2nd remote air ride seat rear wiper
rear defogger 3rd valve fel $53,900 or $43,900 for same but a 7040
/ M8540 or 9540
How do like your 8540s they look great, kubota just has a great look to it
do you ever wish you had more power or the dual speed
/ M8540 or 9540 #7
i upgraded to a 8540 (rops) 12 sp. the only real dif between that & 95 is a few hp & slightly larger ft/rear wheels. actually, the 2 different size wheels are interchangeable on the 2 models. i moved up from the 7040...too many adv. from that move to list here other than the transmission lock on the 85 is much more positive than the 70 along w/more fel cap & 3 pt hitch capability... the 8540 is a dream, & i strongly recom. the 12 hd tranny that also has a much higher 3 pt. lift cap. can't really say about the swing shift tranny opt. as the 12 sp. will be everything i'll ever need. not 1 complaint after 3 yrs, the "general" keeps making the otherwise mundane a blast..... good luck on your choice.
/ M8540 or 9540 #8
Our dealer orders the M8540s with the same tires as the standard M9540 which I really like. I am sure there are some differences between the two, but they are minor with the exception of the 24F/24R transmission not being available in the M8540. We have no need for a 24F/24R, so this was not a consideration.
We were prepared to buy either the M9540 or M8540. Money was not really a consideration as this will probably be the last tractor of this size we will buy. According to the salesman, the M9540 burns a little more fuel, but if you take out the transmission option, there is little difference beyond the ten additional HP. We were trading in an 80 HP machine which had all the power we needed, so we went with the M8540 and have no regrets. We use ours mostly to pull a Woods DS1260 10'6" rotary cutter and to do dirt work. We have never run out of power. If we were going to pull a 15' bat-wing, we probably would have gone with the M9540.
The engines are the same as are the 12F/12R transmissions.
That is a very good price on the M9540 the way it is set up.
/ M8540 or 9540 #9
I really am very happy with mine.
It has all the power I need and so far I have found no need for duel speed.
E/S
/ M8540 or 9540 #10
I may be wrong, but I think that the 24 speed is really only needed if you are using the tractor for farming. So you can easily get whatever speed and power you need to do whatever it is that you are doing in the fields.
Just a guess. :confused3:
/ M8540 or 9540
How about take a picture with your camera of the speed chart. does it say how wide it would be 16.9 34s thanks for all your help guys
/ M8540 or 9540 #12
/ M8540 or 9540 #13
I will give this a shot, if it doesn't work, PM me and maybe it will work better as an email attachment.
/ M8540 or 9540
Thanks for doing that, it is perfect just what i wanted to see. thanks for it is much appreciated. I think this is the best fourm on the web :thumbsup:
/ M8540 or 9540 #15
Glad I could help, a lot of TBN members sure have helped me.
/ M8540 or 9540 #16
TripleR/dieselbill, I rotated the orientation to make it a little easier to read. Was straining my neck to see that last column. :laughing:
/ M8540 or 9540 #17
Thanks, that is a lot better.
/ M8540 or 9540 #18
"twas me I would widen your blade a bit rather than narrow the tractor.an 85 will push a 10 ft blade but a nine foot angled fits better.I once widened mine and put pieces of grader blade for cutting edge,since it was thicker it stopped the blade's tendency to wear in a curve.I have pushed snow on the south shore of georgian bay for 30 yrs.
Stidham 2 Horse Trailer (A65640)
Stidham 2 Horse...
New Quick Hitch (A65579)
New Quick Hitch...
John Deere 2 Row Corn Planter (A65579)
John Deere 2 Row...
2023 Wolverine DM-13-72W Mulcher, Skidsteer Mount (A62679)
2023 Wolverine...
2011 Polaris RZR 900  (A62679)
2011 Polaris RZR...
2018 Freightliner M2 106 20Ft. Reefer Box Truck (A64194)
2018 Freightliner...
