WALT
Gold Member
But I do have a couple of questions for any other L39 owners.
1) just back chains or chains on all 4 wheels?
2) what chains as their appears to be no room between the tire and fender at the back. Maybe wheel spacers?
3) front snow blade or inverted pto snowblower
MBradley:
Welcome to the forum. I bought an L-39 when the L-39 was introduced by Kubota, and have 600 hrs. on it. Do a search of my posts and you may find some of them useful to you.
1. I bought chains for all 4 tires after some close calls on icy hills, but the rear chains are the most important. I use the spiked forestry chains from tirechainsrequired.com. They will need to be cut and adjusted to the tractor, along with using the H/D chain tensioners. The front chains are marginal due to the fact that your front axle load varies while plowing. Make use of your dual brake pedals to assist with your steering.
2. As stated, the rear chains do fit without spacers.
3. I have a snow plow blade that quick attaches to the loader by removing the bucket. I leave the B/H on for the rear weight as well as being able to use it to pull yourself out backwards if you get stuck.
While some here while give you a different opinion, the R-4 tires do not grip well in deep snow or ice, especially on inclines. I have found that plowing down hill, even with the chains works much better than not.
My photos are not on this computer, so search my old posts for plow/chain photo's.
WALT
MBradley:
WALT
