Switch for snowblower chute control
/ Switch for snowblower chute control #1
tsteahr
Gold Member
CT shoreline
Massey Ferguson GC2410tlb w/ R1 and Rimguard
Hello,
I'm looking for some help finding a multi throw momentary switch that I can use to control both electric chute rotation and electric deflector on my 48" RAD blower. Ideally I'm looking for something weather tight. I found this which looks like it might work, but it does not look very weather resistant.
Has anyone come across a nice switch for this application?
Thanks
/ Switch for snowblower chute control #3
You can also buy a one piece weatherproof boot that is molded onto the securing nut for the switch. They are usually a grey silicone type rubber that slips over the switch lever. Might be listed separately from the switches.
/ Switch for snowblower chute control #4
/ Switch for snowblower chute control #5
Have you checked with your dealer? Might be more $$, but the ones they used on my 2310 work and seem to be holding up well.
You can see the two switches in the pic, one on either side of the dashboard area. They're both rubber-coated. On mine, the switches were dealer-installed-- they might have them in stock.
Thanks for the links guys. Looking at this I realized a 4 pole double throw is NOT what I need. I'm looking to combine four functions into a single switch, like a toggle joystick. So I can have up/down and left/right available on the same switch by moving the switch in any of four directions.
Now I'm not sure exactly what I need. I'm thinking I need perhaps 6 poles. Two poles for voltage input (12v hot and ground). Then another 4 poles for control of each of the two motors. Am I on the right track with this? :confused2:
/ Switch for snowblower chute control #7
I used two DPDT momentary switches. One controls up/down, the other left/right. Found them at Radio Shack. Not weatherproof, they are inside the cab. I used one of RS's project boxes to mount them at hand height when turned sideways in the seat. But then, I snowblow in reverse. And warmth.:p
/ Switch for snowblower chute control #8
Where you buy your switch from think in terms of availabitily if you ever break the new switch. Remember you will be wearing gloves when you are operating the switch.
Craig Clayton
Yes, that is an option for me to just install a second, seperate DPDT. I may have to go that route if I can't find a a switch that lets me combine all functions into one.
Craig Clayton
Good point. I would plan on buying one or two spares just for that possibility. Most of these switches are around $10-$15 so getting a couple spares won't break the bank. I'd order a few spare weather boots as well.
/ Switch for snowblower chute control #10
What about going with a retro joystick from a video game? Would have to hook up some relays to increase current ratings, but if they had 4 micro switches mounted in the base it should work. You could also look at the joystick from a honda 928 snowblower. I have this blower and it uses a joystick form the chute and damper. or maybe this?
http://cgi.ebay.com/Joystick-4-way-...ultDomain_0&hash=item4156ee7173#ht_500wt_1156
/ Switch for snowblower chute control #12
You are not going to find this type of operation in a standard toggle. Either go with a joystick as others have suggested or seperate switches.
Yep, you are right. That is the conclusion I am comming to. I'm going to go with a seperate DPDT switch. If I get into a joystick and relays I'm getting close to the cost of the linear actuator (just for control function) and I don't feel like making this more of a project than it needs to be.
Second switch it is. Thanks everyone. I appreciate all the replies and info. TBN is great. When when someone has a question, Bam! folks step up to the plate and help out. Awsome!
/ Switch for snowblower chute control #14
Joystick 4-way toggle switch, Industrial/Medical UNUSED - eBay (item 280631341427 end time Feb-23-11 14:42:29 PST)
Brilliant. I wanted to build a joystick control for my hydraulic chute control, but couldn't find one that fit my application.
JayC
/ Switch for snowblower chute control #15
This switch is NC. Make sure that will work for you...
Like you said most video games are very low current, think ~10 mA. So you would need a relay for sure, perhaps a relay for the relay :D I looked into a joystick to run a plow and was for the most part let down at what I could find; either very low amperage rating or HIGH $$$. This was the 'best' thing I found JOYSTICK 1000 MICROSWITCH 6A - 1D27F1500 It handles 6 A and $60, comes with a rubber boot for the joystick but I am not sure how weather proof it would be.
Chad
/ Switch for snowblower chute control #16
I'd just go with two DPDT center off toggle switches OR two winch controller pushbutton pendants such as a Ramsey or Warn remote. They are weather proof but quite a bit more money than a normal McGill toggle.
I've always found that its easier to just replace a standard switch when it starts to act up. Keep it sprayed with penetrating oil and it will last for years even out in the weather, as long as it has enough capacity for the load.(and doesn't get salted)
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
2014 Lincoln MKS Sedan (A61574)
2014 Lincoln MKS...
4ft Mini Skid Quick Attach Rotary Cutter (A63689)
4ft Mini Skid...
2006 Sea Ray Sundancer 31ft Boat w/ Loadmaster 28ft Tri-Axle Boat Trailer (A61574)
2006 Sea Ray...
REDDICK FRONT MOUNT TANK (A63291)
REDDICK FRONT...
2007 Genie AWP-30S 30ft Manlift (A61572)
2007 Genie AWP-30S...
