Revised Ohio Commercial Vehicle Rules
/ Revised Ohio Commercial Vehicle Rules #21
Incorrect, FEDERAL is any vehicle with a towed unit that is over 10K that crosses state lines OR a 26,001 GVW (license, rated, actual) unit with or w/o towed unit.
Laws very by STATE that may say the total GVW of both needs to be over 26K, I know MN is this way, but Federal is anything in commerce with a towed unit over 10K crossing state lines.
Sorry Bud you are wrong here.
Question 2: Is a driver of a combination vehicle with a GCWR of less than 26,001 pounds required to obtain a CDL even if the trailer GVWR is more than 10,000 pounds?
Guidance: No, because the GCWR is less than 26,001 pounds
Interpretation for Part 383.91: Commercial motor vehicle groups. - Federal Motor Carrier Safety Administration
/ Revised Ohio Commercial Vehicle Rules #22
One of the trucks is registered to my wifes business. The other is primarily used for maintaining and rehabbing investment properties. This truck is only driven by me. I am not exactly sure if that truck is "commercial" or not.
Trailers are pulled by both trucks for personally owned rental/rehab properties. The trucks are not driven by employees.
When you pull trailer for rehabbing rentals you are technically a CMV. The odds that you ever get busted for this are slim to none if you don't mind fibbing a bit if you get pulled over. It also make no difference if it is owner operated or employee operated.
I wonder if the guy hauling personal tools to jobsites would be considered a cmv?
/ Revised Ohio Commercial Vehicle Rules #25
/ Revised Ohio Commercial Vehicle Rules #26
What if his "tool" was a D-11 Caterpillar? :laughing:
Where is the line drawn?:confused:
Then it would be kind of moot anyway since he would need a CDL.
Simply put if I haul "my" tools as a self employed contractor in a truck or combo over 10k GVWR/CGVWR/GVW it is a CMV.
If I haul my tools as an employee of someone else it would not be.
That is what bothers me about it. The guy that has a 1 Ton truck for pulling his weekend toys. Or the finish carpenter that pulls a trailer because he prefers his own tools.
That being said, I have also been in some pretty scary under 26,000 lb company trucks.
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A61567)
2016 Ford F-150...
2005 Katolight VSD60FGJ4 60kW Standby Diesel Generator (A61572)
2005 Katolight...
UNVERFERTH PERFECTA II 18' FIELD CULTIVATOR (A63291)
UNVERFERTH...
2021 TAKEUCHI TL12R2 SKID STEER (A64279)
2021 TAKEUCHI...
2006 Sea Ray Sundancer 31ft Boat w/ Loadmaster 28ft Tri-Axle Boat Trailer (A61574)
2006 Sea Ray...
2001 Peterbilt 379 Tri-Axle Dump Truck (A59230)
2001 Peterbilt 379...
