3-Point Hitch Additional SCV's
   / Additional SCV's #1
Stormtruck2
Mechanicsville, Iowa
02 JD 4600 FEL, 72 MM Mower, Cab
I have a 02 4600 Hydro, FEL, Cab. I am wanting to put a 3pt snowblower,(with hydro chute rotation, deflector tilt) hydro box blade, hydro rear blade, and hydro top link, on it. I currently have 1 valve set up on the back. I'm thinking that I will need 3 more additional SCV on the rear. How hard is it to add those valves, and should I get the parts from JD or else where. Mr. Goodwrench I'm not. I'm more of a Mr. Goodgod what did you do? :laughing: Any and all hints, suggestions, and what ever you do, don't do this, that you care to send. :thumbsup:
   / Additional SCV's #2
Much has been discussed in other threads on SCV's. A search on SCV with member kennyd specific would be very helpful reads for you to get started. There are a few different ways to go.
Hang in there and do some reading for the options available to you. :)
   / Additional SCV's #4
JD only offers the one remote you have-so going with all JD stuff is not gonna happen...
There are two choices here:
One) plumb in a new two or three spool valve using the "power beyond", It will be all custom-you will have to make bracket for the valve and get all the hoses made. Probably about $500-$700.
Two) You can add electric "diverters" and effectively "split" the one remote you have into as may as you like, each function would be selected by a switch. This is the easy way to go, and a little cheaper also, the downside is that only one function can be used at a time;
Here are two threads that show the diverter idea very well:
Electric Selector Valve Install - TractorByNet.com
3320 diverter installed - TractorByNet.com
   / Additional SCV's #6
Storm,
I just checked jdparts and realized I was wrong, there is a 4th and 5th kit available from JD- part number BM19588.
   / Additional SCV's #7
There "was" a 4th and 5th kit. It is NLA, you would have to do piece by piece most likely far exceeding the actual value. ex, the valve alone is over $500. Better go the aftermarker route if wanting to save some dough.
   / Additional SCV's #8
They are out there...just gotta search;)
Native American Wooden Statue (A55853)
Native American...
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2021 Chevrolet Equinox LS SUV (A55853)
2021 Chevrolet...
2016 Volvo VNL Truck, VIN # 4V4NC9TH4GN955551 (A57453)
2016 Volvo VNL...
John Deere 1025R (A53317)
John Deere 1025R...
