Snow Recommended RPMs for 2 stage snowblower
   / Recommended RPMs for 2 stage snowblower #1
OldBulldogger
SE Minnesota
Ford 1720 4WD
Hello snow enthusiasts,
I am looking to put a front mounted snowblower on a Ford 1720. I came across a 2:1 PTO increaser that was mounted on a 1720 and redirects the PTO output shaft forward so that you can run a front blower or broom. Supposedly it was made by Ford. It is gear driven and fully enclosed. Also, it mounts to the drawbar for support. My question is this, what PTO speed is recommeneded. I am looking to put a Ford 715 blower up front. Being it is 2:1, it will inrease the rear 540 pto to 1080. Is that too fast for a blower?
I know some models of 1720s came with a mid mount PTO for use with a blower but I am not sure what the RPMs is on those.
Any advice would be much appreciated.
Thanks!
   / Recommended RPMs for 2 stage snowblower #2
Thanks!
What's the blower designed for? if it's designated as 540 rpm, you''ll have to run the pto at a slower speed if there is a a step up gear box on the drive or get a blower that will take a 1080 rpm input speed.
   / Recommended RPMs for 2 stage snowblower #3
Either that or run it WOT and throw snow like crazy.
larry
   / Recommended RPMs for 2 stage snowblower #4
I had a David Brown/Case tractor with a 540 and 1000 pto and a lucknow snowblower on the back
I used the snowbower with the 1000 pto speed and the tractor revving at 1700 she could sure blow the snow.
I now have a New Holland TD95D with just the 540 pto and a lucknow snowblower on the back.
Would like to know if thwere is anyway to get my 540 pto to spin faster as I really miss my 1000 pto on my old David Brown/Case tractor.
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A55973)
2017 Freightliner...
2016 Peterbuilt (A56858)
2016 Peterbuilt...
2006 Caterpillar 315C L Hydraulic Excavator (A56857)
2006 Caterpillar...
Mini Skid-Steer Stump Grinder (New/Unused) (A59225)
Mini Skid-Steer...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2019 INTERNATIONAL...
2015 John Deere 544K Articulated Wheel Loader (A55973)
2015 John Deere...
