leaking NPTF quick connects
/ leaking NPTF quick connects #1
myyaz33
Nebraska
TYM T273
Bought the following adapters and quick disconnects (6 total) and am having a **** of a time keeping them from leaking. I started off without any sort of sealant or lubricant and didn't over tighten but they leaked. Then I tried tightening more with less leakage. Tried both PTFE paste and Teflon (against advice, I know). Nothing seems to work. I am now wondering if the threads are toast. Any ideas or tips. Not really interested in a war of tape or no tape.
http://www.discounthydraulichose.com/product_p/5501.htm
http://www.discounthydraulichose.com/ISO_7241_Series_A_Quick_Disconnect_Coupler_p/601-xx.htm
/ leaking NPTF quick connects #3
It's possible they sent you ORB female ends on the quick connects instead of NPTF. If so they'll keep leaking. I think they're the same thread-per-inch count.
Mine don't leak a drop, and they're sealed with you-know-what.
Sean
We use this for industrial applications. I use it at home. Nothing close to it.Loctite ョ 567? - Henkel
Does this stuff need to cure?
Sean
Possibly, but I wouldn't know the difference.
I am thinking about just doping them up good and cranking the **** out of them and if it don't work, buying some more adapters and quick connects and starting again. If I could, I would rather not use the NPTF couplers, but that is all I can find.
/ leaking NPTF quick connects #5
That is exactly what I would do. If you use PTFE past, then also give it some cure time...
/ leaking NPTF quick connects #6
Sean
The unfortunate reality is that:
1/2" NPT and #10 SAE ORB are the exact same thread per inch & the Out side dimensions are similar enough they will some what interchange.
3/4" NPT and #12 SAE ORB have the same condition.
You can some times tell the difference on female ends since the SAE ORB port will have chamfer or lead in angle of 12 - 15 degrees. Pipe threads some times have an angle but it is usually closer to 30 degrees.
Yes Loctite has a cure time and prefers clean dry threads for assembly. Oil on the threads tends to reduce its effectiveness.
Roy
/ leaking NPTF quick connects #7
You probably have deformed the threads too much, and about the only fix is to replace both the fittings, and start over with new fittings, and a sealer.
/ leaking NPTF quick connects #8
We do not stock the 600 Series Couplers (ISO 7241-1 Series A) with SAE/ORB thread, so it's very unlikely that you have the wrong thread. You can eliminate that possibility right there.
I'm sorry to say that JJ may be right. You may have worn out the threads by now. Replacing the couplers, the elbows or both may be your only option at this point. Without seeing the fittings myself, I can't really guess why you are having this problem.
Give us a call if we can be of further assistance.
I think you are probably right.
Agreed on them being warn out. Any thoughts on how many turns those 2 fittings together should have or how many threads should be showing when properly tightened?
/ leaking NPTF quick connects #10
If its orb the 45 should screw in preety much all the way in easily. If they are right for each other they will screw in just a few threads. Teflon pipe dope is all you need. No cure time needed. Make it tight. No leaks
As HHG stated they don't stock those fittings with the ORB thread and I did buy them from them so I agree that the ORB threads are ruled out.
HHG- Wanna take those 2 fittings into your lab and give me a idea of how many cranks I should be giving them? :)
/ leaking NPTF quick connects #12
I don't believe there are any set numbers of turns. Just turn it snug with sealer, and check for leaks. If it leaks, tighten a little more.
/ leaking NPTF quick connects #13
If the threads are "worn out", then you have nothing to loose trying what you suggested in post #4.
That will be the plan, well when it warms up a few degrees..
/ leaking NPTF quick connects #16
Id say you must have cross threaded them. It would be have to be screwed on many many times to be worn out in normal circumstances. Buy new ones and have someone that knows what there doing assemble them for you.
/ leaking NPTF quick connects #17
I guess I gotta ask, Are you sure it's the threads leaking? I received some bad QC's on my grapple that leaked and were replaced by the seller because they had gotten a bad batch from the manufacturer.
/ leaking NPTF quick connects #18
How often do you actually use the quick disconnects? If it's daily, they might be worth the effort. I put them on my tractor for my grapple and fond that they are such a pain to deal with that it's not worth having them. I took mine off nad just put regular fittings on there to tighten and untighten with a pair of wrenches. If I have the bucket on, I just screw on a cap to keep the ends clean. It's made life so much easier for me just doing it this way.
Good luck,
Eddie
Positive they are not cross threaded. I am also confident that I have the skill needed to accomplish this without going to someone "that knows what there doing". :)
Quite certain, I can actually watch it seep out.
Good luck,
Eddie
I use them often so will have to tackle this. I have attached a picture from the day I installed the rear remotes so you know what I am talking about.
See this thread for the details of the addition of the remote.
http://www.tractorbynet.com/forums/tym-owning-operating/124652-rear-remote-options-t273.html
Year: 2015 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82,002 (A64557)
Year: 2015 Make...
Swict 60in Bucket Skid Steer Attachment (A64553)
Swict 60in Bucket...
JOHN DEERE 467 ROUND BALER (A64278)
JOHN DEERE 467...
2016 Freightliner M2 106 S/A Day Cab Truck Tractor (A64194)
2016 Freightliner...
2005 Toro Workman Utility Cart (A64194)
2005 Toro Workman...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2018 FREIGHTLINER...
