Oil wt for jd 4700
   / Oil wt for jd 4700 #1
al20hp
Member
Jd 4700
I bought a 10 year old jd 4700. What wt oil should I use? I live in north east pennsylvania
Thanks. Al
   / Oil wt for jd 4700 #2
Welcome Al:
Do you have the manual for the tractor? If not, you can purchase one at John Deere Technical Information Bookstore - Home Page Get the CD as its usually half the cost of the hardcopy and you can print out replacement pages as needed. If you're going to be doing you're own maintenance and repairs, the shop manual is worth owning too.
The owner's manual can also be viewed here. Introduction
   / Oil wt for jd 4700 #3
I have been running 15w40, 5w40 and now 0w40 oil in my JD 4700.
Just pay attention to the temperature and oil type used.
Later,
Dan
   / Oil wt for jd 4700 #4
I'd put Shell Rotella T 15W-40 in it. Available at Walmart.
JayC
   / Oil wt for jd 4700 #5
I use Rotella T 5W-40 synthetic in everything I own. You only need to stock one oil that way.
I do the same thing - except with Rotella 15W-40 dino oil. Mowers, dirtbikes, tractors...everything gets the same oil.
JayC
   / Oil wt for jd 4700 #6
See your friendly Deere dealer. They have the oil specific for diesel and will be good to know if other parts are needed.
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2021 CATERPILLAR 317 EXCAVATOR (A51242)
2021 CATERPILLAR...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2013 CATERPILLAR 420F BACKHOE (A51242)
2013 CATERPILLAR...
2015 FORD F-250XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-250XL...
LINDE H70 FORKLIFT (A50854)
LINDE H70 FORKLIFT...
