Price Check 1994 Kubota L5440
/ 1994 Kubota L5440 #1
baxterl
I am looking at 5450 with 1550 hours 4wd with FEL. They are asking 11000 is this a good ballpark price?
/ 1994 Kubota L5440 #2
yes thats a great price if everything on the tractor is in working order.plus its a low hour tractor.
/ 1994 Kubota L5440
Tks everything seems to be working.no visible leaks. Also includes a six ft sherdder and set of hay forks.
/ 1994 Kubota L5440 #5
I don't believe there is a model L5440 - Is it really L5450 maybe? If so the price seems very low (maybe too low). Does it have the ever clutch? (Big letters EC on the side). Private sale or dealer? A pic or two would help get more information. Take care, Dick B
/ 1994 Kubota L5440 #6
For the benefit of others, very good write up rebargeron:TractorByNet.com | Reviews
/ 1994 Kubota L5440 #8
A L5450 4wd and FEL with 1550 hours in good mechanical condition would usually be expected to be in the $15k -$18k range. If it is in decent shape it should sell very fast at $11k.
I've seen some down in the $10k-$11k range but they had issues - one had 3700 hard hours on it, another had severe engine blow-by, another needed a front axle and hydraulic pump. But now and then great deals happen so check it out, make sure it all works, and pounce! - good luck.
/ 1994 Kubota L5440
It is a L5450 typo on my part. It has the ever clutch and is a private sale.
/ 1994 Kubota L5440 #10
Dick, does your L5450 accumulate hours on a minute = minute basis? I know my L4850 does not but bases it on the engine RPM.
/ 1994 Kubota L5440 #11
Hi Mark, great to hear your voice!
No, the meter is strictly gear-driven from the engine and doesn't use time at all. The needle is magnetic so it's not perfectly accurate - but the counter is gear driven and there's no slip. It is geared so that it shows an "hour" for a fixed number of engine revolutions, usually around 150,000 for a tractor diesel. At full rated engine rpm, it logs an "hour" per actual hour. (2500 rpm for 60 minutes = 150,000 turns) But idling at 625 rpm it would take 4 hours to log an "hour" on the meter.
Many machines have gear-driven meters that count engine turns - it's a reasonable surrogate for actual engine usage and oil wear, although it ignores other factors like number of warm-up cycles, average power delivered, length of runs, average oil temp, dp across the filters, etc. Adding enough sensors for all that would push up the price. The counter is close enough.
Since I added 2-speed pto's to both my L5450's I rarely rev the engine above 1800-1900. So their "hour" count is about 25% lower than my actual seat time. Oh No, my secret's out ! I better call the guy who bought the canopy rig and confess ! :D
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
1999 Ford F-150 4x4 Pickup Truck (A59230)
1999 Ford F-150...
2018 LIEBHERR A900C LITRONIC WHEELED EXCAVATOR (A63276)
2018 LIEBHERR...
2019 FORD F-150 XLT CREW CAB TRUCK (A63276)
2019 FORD F-150...
2008 New Holland T2420 (A62177)
2008 New Holland...
2014 Subaru Legacy AWD (A62613)
2014 Subaru Legacy...
