Tiller Too much HP for 4' King Kutter Tiller??
   / Too much HP for 4' King Kutter Tiller?? #1
deereman10
Elroy, WI
John Deere 2440
i have a John deere 2440 with about 45-50 HP. King Kutter recommends their
4' tiller for any subcompact tractro up to 25 HP. Is my tractor TOO much for the tiller? Is that possible?
   / Too much HP for 4' King Kutter Tiller?? #2
Assuming the slip clutch or shear bolts are correctly sized, I don't see what the problem would be. 4 feet is going to be narrow for your tire tracks.
   / Too much HP for 4' King Kutter Tiller?? #3
As long as you have the proper shear pins, slip clutch etc. and the clutch does slip when it is supposed to you wont have any issues as krazsk has mentioned.
I would be more worried about the slip clutch being clean and making sure it works properly is so equiped as you can wad a roller chain really quickly.
What you want do is break the soil completely.
You will need ot make your initial full width pass very slowly and then take hal passes for the remainder of the width.
After this is done you shoud check or any ridges along the edges of tilled width and if so till at a right angle repeating the same steps.
If you have access to mason sand from a gravel pit this would be a good time to add some as well as any green manure or compost.
   / Too much HP for 4' King Kutter Tiller?? #4
yep.. set clutch to protect tiller.. should be fine and tedious...
soundguy
   / Too much HP for 4' King Kutter Tiller?? #5
Youre going to have to set the slip clutch high enuf that it will start to significantly bog your engine before it slips. Otherwise you will burn the slip clutch up real quick because you wont have a good indication of imminent or ongoing overload. Hopefully the telescoping PTO shaft will be stong enuf that it wont twist ~70HP x 540 rpm torque.
larry
thanks guys.
krazsk, the tiller is offset to cover up the tire tracks
   / Too much HP for 4' King Kutter Tiller?? #7
larry
once the clutch slip point is met.. that's all the pto sahft will see.
soundguy
   / Too much HP for 4' King Kutter Tiller?? #8
thanks guys.
um.. 4' tiller? unless that 50hp machie is reaaaaaaaaal narrow.. it ain't covering the track(s).. :) only 1.
soundguy
yeah it covers the one tire that is in the tilled dirt leaving the tire thats on the untilled dirt uncovered..
   / Too much HP for 4' King Kutter Tiller?? #10
I ran an offset tiller on my Cub Cadet for 14 years..............
I hated that thing
Get to the end of the garden..........1 tire on solid ground, tiller is on a sharp angle. Turn the other way..........now the exposed tire is sinking in the soft dirt. Just created more problems with weeding and so forth, than what it was worth. JMHO
cummins generator (A56857)
cummins generator...
2012 DOOSAN G25KW GENERATOR (A55745)
2012 DOOSAN G25KW...
2013 Chevrolet Traverse AWD SUV (A56859)
2013 Chevrolet...
2014 International Bucket (A55973)
2014 International...
Hose Reel (A55758)
Hose Reel (A55758)
2013 Ford Fusion SE Sedan (A56859)
2013 Ford Fusion...
