Glow plug circuit dash element function?
/ Glow plug circuit dash element function? #1
PCweber
Kubota B8200
Can someone explain what the function of the little heater eliment in the dash is to the glow plug system? I realize if it is a cold dark night you can see it get red hot but 95% of the time we use these machines during daylight hours and get no valid feedback from this device. Does it also perform some type of vairable resistance function in the circuit to protect the plugs or something?
/ Glow plug circuit dash element function? #2
If I'm not mistaken, it indicates when the glow plugs are receiving power from the electrical system. In cold weather, I turn my key to the left just enough to light this indicator for a few seconds to preheat the plugs before I try and start the engine. Depending on how cold it is determines how long I preheat the plugs. If it's below freezing, I hold for ten seconds or thereabouts.
/ Glow plug circuit dash element function? #3
You hit it exactly, variable resistance ...
That element is in series with the glow plugs... As it heats the resistance increases and allows you to hold the glow plugs on for a long time without chancing burning out the glow plugs...
KennyV
84in. Light Duty Fork Extensions (A65640)
84in. Light Duty...
PORTER CABLE AIR COMPRESSOR (A65643)
PORTER CABLE AIR...
2008 Kawasaki ZX1000 Motorcycle, VIN # JKAZXCE1X8A013733 (A65563)
2008 Kawasaki...
5x8 Utility Trailer/Peanut Stand (A65563)
5x8 Utility...
2005 little wonder high output blower (A64557)
2005 little wonder...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
