I have now seen it all
/ I have now seen it all
Could have used it a month ago when I got stuck towing logs out of the hole out back...
Nutty Eastern Euros...
/ I have now seen it all #5
Yes that is a good one.
My Dad and I used a similar method with a D31A Komatsu dozer years back. The cat was stuck good in the muskeg so we chained a 10" log to both tracks at the front idlers and walked right out.
We were quite happy because when you have a tracked machine mired down like it was....Well it ain't pretty!
/ I have now seen it all #7
I knew a guy who keep a extra wheel, no tire, in his truck He had weld on a length of chain and could use it like a winch. Say you are stuck, one wheel off front or rear, mount this spare wheel, now hook the chain to a tree ect, put truck in low gear, and allow it to spool up.
Said he got the idea from a episode of Macgyver.
Chris
/ I have now seen it all #8
What did the Fellow do to keep the other wheel from spinning?
Jacking up a rear tire and using it to power pipe cutters and threaders was a common practice at one time in some places.:D
/ I have now seen it all #9
Dont even have to go look at you tube my friend and i when we were 15 or so were cutting wood for his grandfarther and we got their Farmall super M mired in black mud. The old fella came out cut a 8 inch ceder bout 8 feet long and chained it to both wheels .We were out in one almost compleate rotation.**** of a trick. am i close?
/ I have now seen it all #11
Ah, heck. I saw that on the Red Green Show.:D:D
/ I have now seen it all #13
They taught us the very same method to get tanks out of mud. LOL, the side comment was that you keep doing it till the tank is in all the way to the turret and than call the recovery tank:thumbsup:
Talking T55s here:)
/ I have now seen it all #14
Actually Nutty Northern men. Those are Swedes. Dont know why the Sputnik text is there.
/ I have now seen it all #15
Not sure. I have seen the wheel powered log splitter that is shaped like a cone also.
Chris
/ I have now seen it all #18
When I was a teenager with one of my dad's tractors stuck in a field up near the road, one of the neighboring farmers stopped by with some split firewood and chains. We strapped a piece of split wood crosswise across each rear tire like paddles. The tractor lifted up and took a step forward every time both the paddles hit the ground. He tought me a neat trick that has saved me some digging over the years. I still think of him whenever I get stuck.
/ I have now seen it all #19
Very creative!
I would always use 4wd and always have a rescue vehicle nearby.
The logs are creative, but the downside could be a bummer.
/ I have now seen it all #20
I've seen this done many times in the past before we had winches handy. My Dad showed me this trick when I was about 10y/o (several yrs ago) and most of the time it works well. Just be sure that you have a strong piece of timber. I once knew a fellow who wrapped the chain around the tire and the outcome wasn't so good--he broke an axle. The main thing is to be very very careful because that piece of timber is under a lot of strain!!! But it WILL work. Belah:thumbsup:
