OP
        turbopiper
Member
Well, finally got around to having time to pull the old battery out to put the new 24R battery in, but I ran into a problem. Getting the old battery out is not as easy as I wanted it to be. I figured to just tilt the battery forward and lift it up and over the hood latch, but it seems the battery is larger than that opening. Looks like I'll have to remove the small frame in front of the radiator that holds the battery and slide it out through the back of the frame after it's out. What a PITA...
Seems I'll be returning the 24R battery and look at buying a battery that I can tilt in and out the front over the hood latch as I need to, without taking the frame out again.
Has anyone run into this problem before?
Ted
Ted
