Deere 4300 stuck in gear
   / Deere 4300 stuck in gear #11
Might be some broken parts in the tranny.
The moment of getting stuck was when I ran forward in close parallel to a fenceline, got too close and had to back away, and all of a sudden couldn't go into reverse.
Something about the description that doesn't feel good, as just getting close doesn't seem to be threatening, but if sudden change in direction there may have been something coming apart. Hope not, and hope it is an easy/cheap fix for you.
   / Deere 4300 stuck in gear #12
Coincidental, I think...
This comment: For as long as I've owned it (about 4 years) the gears tend to grind slightly before shifting into gear when I first start up cold, in an earlier post, gives me pause.
However, HorseCrazy is smart enough not to dig into the gearbox (due to lack of mechanical knowledge) and let someone who does have those skills dig into it.
I just hope it's something simple.
   / Deere 4300 stuck in gear #13
Well, no luck so far. I lubed the gear shifter where it goes into the transmission. I jacked up the left rear wheel and rocked it back and forth while trying to shift. No luck. Shift lever still won't budge.
I'll give my mechanic friend a call in a day or two. If anyone has any other ideas, let me know.
Just gotta get it fixed, one way or the other, before the next big snowstorm hits. (I live in the Catskill Mountains in upstate NY.)
Many thanks.
HC,
Did you get your 4300 fixed ??
KOMATSU PC130-8 EXCAVATOR (A50854)
KOMATSU PC130-8...
GENERATOR HOUSE POWERED BY TWIN (60 SERIES)  DETROIT 14.0L ENGINES (A50854)
GENERATOR HOUSE...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A51039)
Neckover GL24-2-7K...
2012 SULLIVAN PALATEK AIR COMPRESSOR (A51222)
2012 SULLIVAN...
2004 Ford F-250 4x4 Crew Cab Mechanics Truck (A49461)
2004 Ford F-250...
