Box Blade and Weeds in Gravel
   / Box Blade and Weeds in Gravel #21
Most of you probably already know this, but for those who may not, Glyphosate is pretty expensive because rather than being a poison, it is a synthesized hormone. It is only taken into a plant through the leaves and it works the same way the natural hormone does that turns off the root functions. Like the natural hormones in all plants, it breaks down and decomposes fairly rapidly. For me, the issue is not environmental, but financial. I'd go broke if I used the stuff everywhere I'd like to.
   / Box Blade and Weeds in Gravel #22
Glyphosate is pretty expensive because rather than being a poison, it is a synthesized hormone.... it breaks down and decomposes fairly rapidly.
Sure there are much more low cost herbicides... you could use 2,4 d. Its about 1/3 the cost of Glyphosate, and if I needed bulk application, it would be higher on my list.
Its more toxic, and the operator needs more PPE than with a Glyphosate product.
   / Box Blade and Weeds in Gravel #25
Just gives you an Idea of what can be done to a road in poor shape with a little work.
   / Box Blade and Weeds in Gravel #26
I have a gravel driveway and in the summer on the sides of the driveway where you don't run over all of the time, the weeds and grass will grow in the gravel. Would running over the area with a box blade dig up the weeds then spread the gravel back down?
Sounds like a job for waste oil.
JayC
   / Box Blade and Weeds in Gravel #27
The 2, 4, d works on broad leaf weeds, but is not effective on grass. The Glyphosate purchased in generic through the TSC in larger quantities is not too bad and your county extension office may also have it for less. It also helps to add a little liquid dishwashing detergent to the mix to help it stick to the plants better. I found that the generic usually took about 2 weeks to kill the weeds vs the Round up which was a few days, but the cost difference was worth the wait to me.
   / Box Blade and Weeds in Gravel #28
JayC.... I hope your well water source is not underneath your gravel driveway. Ouch....
   / Box Blade and Weeds in Gravel #29
or, within a mile of it. You never know which way the water travels once it goes below grade.
   / Box Blade and Weeds in Gravel #30
I use my BB a couple times a year to remove weeds from my parking areas, and a short driveway. It works great. Like others have said though, you'll need to stop every now and then to remove the clumps.
2019 PETERBILT 579 SLEEPER (A51222)
2019 PETERBILT 579...
2013 Ford F-550 Ambulance (A50323)
2013 Ford F-550...
1995 OTTAWA SPOT TRUCK (A50459)
1995 OTTAWA SPOT...
1999 MACK CH613 WATER TRUCK (A50854)
1999 MACK CH613...
SCAN TO RECEIVE TEXT UPDATES (A51242)
SCAN TO RECEIVE...
1982 LeeBoy Motor Grader (A52128)
1982 LeeBoy Motor...
